Idle boucing when first started up and warm?
Old Nov 2, 2007 | 04:41 AM
shortlid's Avatar
Default Idle boucing when first started up and warm?
Now that the weatehr has gotten colder up here in New Hampshire I have noticed a issue when I start up my '99 Accord EX sedan 4 cyl. 5-speed. When I run into the super market to get a gallon of milk and come bac out and start the car. It starts great but a second afetr it starts the idle drops to like 600 rpm then quickly bounces back up once? Then it is smooth and idles at proper range. The wires are new plugs as well. Recently cleaned the TB, and put injector cleaner though it 200 miles ago? What could this be?
Old Nov 4, 2007 | 05:47 AM
A_Rotary_Guy's Avatar
Default Re: Idle boucing when first started up and warm? (shortlid)
Have you cleaned the Idle Air Control motor (IAC)? I have not owned my Accord for long, but I do know that IAC motors in Accords do malfunction over time, and usually cleaning them out with some carb and choke cleaner helps this problem.
Old Nov 4, 2007 | 05:55 AM
ilikehonda's Avatar
if it is only when the car is warming up it is the fiacv. it is located under the tb (its attached). take it off and on the back there is a little brass looking cap. take out the two scews out and you will see a white looking nut. screw that down as far as it will go.
should fit the problem
Old Nov 4, 2007 | 06:10 PM
shortlid's Avatar
Default Re: Idle boucing when first started up and warm? (A_Rotary_Guy)
I would rather clean it good before adjusting anything. Can I take it off and clean it? I have sprayed TB cleaner/Deep Creep throgh the TB while it was on the car recently?
Old Nov 5, 2007 | 05:39 PM
ilikehonda's Avatar
you are not adjusting anything....you are fixing it. they sometimes they rattle loose and you need to tighten it. ive had to do it 3 times to mine....
Old Nov 6, 2007 | 06:10 AM
shortlid's Avatar
Default Re: Idle boucing when first started up and warm? (ilikehonda)
OK, cool. Do you have any pics? It is way down there can't see it well?
Old Nov 6, 2007 | 06:49 AM
TheMuffinMan's Avatar
He knows where you live!
There's a tutorial about the IACV and FITV
Just be careful to do it while the car is cold otherwise hot coolant will spill on you.
You may need (should) flush the coolant to get out bubbles after doing them.
Old Nov 6, 2007 | 02:49 PM
shortlid's Avatar
Default Re: (TheMuffinMan)
Cool, thanks that in FAQ ot do-it yourself. I looked over the write up. Can I use TB cleaner instead of the carb cleaner? I think that would be safer since it is less harsh on the seals! Also how much collant is lost in the process? Is tightening the screw required?
Modified by shortlid at 4:47 PM 11/6/2007
zfollette
Jan 30, 2016 02:12 PM
Uncle Ben 1
Dec 1, 2015 11:41 AM
accord 2 door
Aug 15, 2011 05:55 PM
Hunng
Oct 11, 2008 02:43 PM
matt_in_sd
Feb 6, 2005 11:58 PM
