Searched no avail: Wiring up DEFI D-Gauges in 98 Civic
Old Nov 1, 2007 | 11:13 PM
Civiclx's Avatar
Default Searched no avail: Wiring up DEFI D-Gauges in 98 Civic
Hey folks
i was wondering where I can tap each of these into:
D-Gauges (EGT, Boost, A/f)
pink for 02 sensor (what color is the o2 sensor on the 98 civic) is it the black/ white near the ecu and if so what pin is it on?
Black - ground
white 12V (light)
orange - ignition
red - battery (constant?)
Old Nov 2, 2007 | 12:50 AM
confucioussae's Avatar
Default Re: Searched no avail: Wiring up DEFI D-Gauges in 98 Civic (Civiclx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx &raquo;</TD></TR><TR><TD CLASS="quote">Hey folks
Black - ground
white 12V (light)
orange - ignition
red - battery (constant?)</TD></TR></TABLE>
for the ground, light, and ignition, you can hook them up to your climate control. ground is black, light is red with a black stripe and 2 marks, and ignition is yellow with a black stripe. i dont know if hooking it up to the battery is a good idea, i would just double up the connections on the ignition (can be found on hazard harness)
i dont know where the pink goes.
Old Nov 2, 2007 | 08:39 AM
Civiclx's Avatar
Default Re: Searched no avail: Wiring up DEFI D-Gauges in 98 Civic (confucioussae)
thanks, anyone else with experience in this?
Old Nov 2, 2007 | 09:59 AM
Civiclx's Avatar
ttt
Old Nov 2, 2007 | 04:24 PM
Civiclx's Avatar
cmon guys
Old Nov 2, 2007 | 06:10 PM
boostedcivicsir's Avatar
Mr. Badwrench
2 threads needed?
assuming it is an lx:
search anyway but i think ill help you:
should be d7 white shielded wire.
Old Nov 3, 2007 | 08:48 AM
Civiclx's Avatar
Default Re: Searched no avail: Wiring up DEFI D-Gauges in 98 Civic (boostedcivicsir)
thank you, thats what i needed, i was using A6 the primary 02 sensor wire, but switched it to d7 and it works! thanks!
Eran
Oct 1, 2008 10:17 AM
ge_ej1
Apr 17, 2008 05:53 AM
Civiclx
Nov 2, 2007 06:08 PM
TheTealHatch
May 31, 2007 08:11 PM
