What should I do for my 100k miles tune-up????HELP~~!!`
Old Nov 1, 2007 | 08:54 PM
Toofresh559's Avatar
Default What should I do for my 100k miles tune-up????HELP~~!!`
Hey everyone I need some advice on my 00 Lude that had just passed the 100k miles mark and was wondering what should I change or do first to maintain the car?? I know I need to change the clutch thats the first but whats next?? Give me some ideas please thanks. Oh yeah and my maintance required thingy turned orange at first and now it's at bright red!! what am I suppose to do to get that thingy back to green like it was before??? any help?? ideas??
Old Nov 1, 2007 | 09:39 PM
MLBZ521's Avatar
Default Re: What should I do for my 100k miles tune-up????HELP~~!!` (Toofresh559)
Timing Belt, all Belts, Plugs, Wires, Dizzy Cap & Rotor, Filters, Seals? Timing Tensioner Setup, and everyone will recommend going to a Manual Tensioner over the Auto Tensioner..
Anything wrong with your car? Leaking oil?
What's been done in the past? It all depends..
Old Nov 1, 2007 | 09:41 PM
Hawkze_2.3's Avatar
Depends on what has been done before, but timing belt and tensioner are a must, plus it's always good to do a distributor cap & rotor, plugs & wires, fuel filter, air filter, oil change, valve adjustment, PCV valve, clean the EGR, tire pressure, inspect ball joints, 02 sensors, etc... Might also run some Seafoam through it
Old Nov 2, 2007 | 05:05 AM
ConanDan's Avatar
Default Re: What should I do for my 100k miles tune-up????HELP~~!!` (Hawkze_2.3)
go to a dealer for the ball joints, Im pretty sure that there is a recall on them.
Why would you need to replace the clutch? Ive heard these things run into the 200k mark
Old Nov 2, 2007 | 05:09 AM
vinuneuro's Avatar
Use only OEM parts and fluids.
Timing belt (and balancer, alternator/ac belts) and Water pump
Valve adjustment (should be done every 30k miles)
Spark plugs and wires (only use NGK plugs and wires)
Distributor cap and rotor should be done every
Fuel filter
Brake fluid (should be changed every 2 years)
Coolant (should be changed every 4 years)
Oil change
Transmission fluid
Snowwhitecoupe
Oct 21, 2011 05:13 PM
jizzer671
Jun 2, 2005 12:40 AM
B2FiNiTY
Jul 19, 2003 12:37 PM
JeremyL
Apr 5, 2003 02:03 PM
4doorLX
Sep 13, 2002 08:36 AM
