Oil Pan Removal
Old Nov 1, 2007 | 05:47 PM
Importcustomx's Avatar
Default Oil Pan Removal
I dont want to have to drop the entire engine to pop off the oil pan..is there an easier way...right now there are 2 bolts being blocked by the exhaust/Tranny
Has anyone pulled an oil pan off without dropping the whole engine and tranny
if so ...please let me know how
i searched..and got nothing so im sorry if i pissed anyone off
Old Nov 1, 2007 | 05:59 PM
reydio's Avatar
you will need to unbolt the bottom half of exhaust, or you can go to:
http://www.crxcommunity.com/viewtopic.php?t=1278
you will need to join to see the full link.
Old Nov 1, 2007 | 07:25 PM
gen2fanatic's Avatar
Default Re: (reydio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reydio &raquo;</TD></TR><TR><TD CLASS="quote">you will need to unbolt the bottom half of exhaust.</TD></TR></TABLE>
Not a very hard task to do. The bolts blocked by the trans you are talking about could possibly be underneath the clutch inspection plate. Just a couple of bolts remove that, and you can easily get to them. Other than that (after removing the downpipe of the exhaust to get to them) its pretty straight forward
Never heard of anyone pulling out the whole engine just to take off the oil pan?? lol
Old Nov 1, 2007 | 08:07 PM
Default Re: (gen2fanatic)
i thought removing that plate would be okay i just wanted to make sure...
im kinda new to just pulling and replacing ****..ive never done an oil pan
I have a gasket..do i need to use anything to put it on?? i just sandwhich the gasket between oilpan and the bottom end...right?
Old Nov 1, 2007 | 09:53 PM
JOE BD-0's Avatar
Default Re: (Importcustomx)
don't forget to use hondabond at the "corners"....good luck
Old Nov 1, 2007 | 11:12 PM
socalrex88's Avatar
Default Re: Oil Pan Removal (Importcustomx)
drain all the oil out first! then support the car on jack stands.. then you gotta take off your exhaust manifold all the way to the cat converter. then there are hundreds of ten mm bolts holding the pan . i think like four closest to the tranny are difficult good luck!
Old Nov 2, 2007 | 02:14 AM
90sedan's Avatar
Default Re: Oil Pan Removal (socalrex88)
Also make you do not over torque the nuts when putting the oil pan back on. They do not require a lot of torque and can be a big PITA if broken.
Old Nov 2, 2007 | 11:12 AM
dem0nk1d's Avatar
i did this last night to my sedan. here is what i did
jacked and supported the car with jack stands.
removed and pulled out the radiator
removed the whole exhaust manifold.
remove a few brackets and the bottom fly wheel cover it's like two bolts that are on the inner pan. then undid all the pan bolts dropping it stright down. cleaned both the block and pan surfaces. then installed the new gasket. i don't use rtv or any sealant. because it's really not needed. makes it a paint when you change it out again. remember to bolt it back up in a cross pattern. from mid then out side etc.... torque is hand tight with a 1/4 rachet.
Old Nov 2, 2007 | 11:46 AM
grog's Avatar
Default Re: (dem0nk1d)
i'm going to do this soon too. do you really have to remove the radiator?
Old Nov 2, 2007 | 12:24 PM
dem0nk1d's Avatar
if you can remove the lower half of the stock exhaust manifold then do that. if not it's easier to remove the exhaust manifold with the radiator out.
Old Nov 2, 2007 | 03:50 PM
welfarepc's Avatar
haha remove the rad thats hillarious!!! thats the stupidest thing ive ever read.
haha yeah lets go and drain out coolant as well! no...
just undo the exhaust undo the bell housing cover, pop out of left axle from the trans (i had to anyways....) drop the bell housing cover, remove the rest of the 10mm's...
(i was able to get the lower bell housing cover OFF with the axle in, but not able to get it back in... )
to pop out the axle from the trans use a pry bar or screw driver, to get it back in use a rubber hammer and gently tap till it goes in (dont tare your boot!)
and to the guy that said he doesnt use RTV on the corners of the new gasket... have fun replacing your oil pan gasket (again) in a few months
oh and this job becomes more fun when you have a 1 piece exhaust like me.. hah
Old Nov 2, 2007 | 03:58 PM
spoonfedcrx's Avatar
pulling an axle? thats almost as stupid as pulling the radiator.
Old Nov 2, 2007 | 09:56 PM
welfarepc's Avatar
Default Re: (spoonfedcrx)
come to think of it you are totally correct! i had forgotten to reinstall the flywheel plate and had to take off the 2 oil pan nuts to get it on!! dohh!!!
haha good call on that.. dont take out your axle the flywheel cover will come out no problem with the pan off haha
Aseegz
Aug 9, 2013 03:03 AM
silverskateEF9
Mar 6, 2008 06:48 PM
oprac
11
Aug 5, 2007 09:40 PM
Cuong-nutz
Nov 4, 2005 10:27 PM
tek_civic
Aug 14, 2003 02:13 PM
