Suspension & Brakes Theory, alignment, spring rates....
camber kits?
Old Nov 1, 2007 | 05:12 PM
tlcivic's Avatar
Default camber kits?
well i just got some Eibach Sportline springs and was wondering if i will need camber kits with them. it says 1.7" drop for my 00 Integra.. and if need camber kits which ones do you guys recommend? Thanks
Old Nov 1, 2007 | 06:33 PM
EK_B's Avatar
Maybe just an alignment will help eliminate the tire wear.
Old Nov 1, 2007 | 06:43 PM
AutoXer's Avatar
Default Re: (EK_B)
With that little of a drop, you won't need a camber kit. I'm running almost 3 degrees of neg camber without one. What you will need is an alignment where they set the toe to zero. Toe wears tires, not camber. Actually with that little of a drop you probably won't even need an alignment, but it's always best to be safe.
Old Nov 1, 2007 | 08:25 PM
tlcivic's Avatar
awesome, i was hoping i wouldnt need them, i didnt want my car slammed..and also Eibach SL Springs with OEM shocks, would my shocks be alright for awhile untill i get Pro-Dampers?
Old Nov 1, 2007 | 08:27 PM
ejprimo's Avatar
Default Re: (tlcivic)
are u atleast gonna get an alignment and fix the toe?
Old Nov 1, 2007 | 09:18 PM
tlcivic's Avatar
yeah i plan on it, but probably couple days after the isntall.. would that be okay? would it wear my tires out quick?
Old Nov 1, 2007 | 10:05 PM
FredoTheChimp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tlcivic &raquo;</TD></TR><TR><TD CLASS="quote">yeah i plan on it, but probably couple days after the isntall.. would that be okay? would it wear my tires out quick?</TD></TR></TABLE>
You can go for a few days, but make sure you get one as soon as possible.
Old Nov 2, 2007 | 10:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote"> Actually with that little of a drop you probably won't even need an alignment, but it's always best to be safe.</TD></TR></TABLE>
Toe changes as the suspension moves up and down, so an alignment is a must no matter how much the drop.
Old Nov 2, 2007 | 10:56 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tlcivic &raquo;</TD></TR><TR><TD CLASS="quote">awesome, i was hoping i wouldnt need them, i didnt want my car slammed..and also Eibach SL Springs with OEM shocks, would my shocks be alright for awhile untill i get Pro-Dampers?</TD></TR></TABLE>
no, stock dampers are not going to be alright.
Old Nov 3, 2007 | 08:12 AM
tlcivic's Avatar
If the stock shocks went out, would it still be drivable? would it cause any other damages to the ride?
Creator
Jan 25, 2010 02:00 PM
gitrdone
Honda Civic (2001 - 2005)
Jun 4, 2006 10:26 AM
dwarrick
May 11, 2006 10:20 AM
civic2000
Jan 7, 2005 11:00 AM
distortedfuture
Dec 5, 2003 10:21 AM
