1997 JR Supercharged Prelude Swap JDM H22A In. PROBLEMS!! PLEASE HELP
Old Nov 1, 2007 | 03:46 PM
redrusch's Avatar
Default 1997 JR Supercharged Prelude Swap JDM H22A In. PROBLEMS!! PLEASE HELP
i have a 1997 prelude none SH. it has a JR supercharger on it. the rings where burnt to **** so i ordered a JDM H22A black top and installed it with the supercharger. i have been trying to get the car to run good ever since the swap, no luck it runs like ****!!. im wondering if anyone has had his problem or knows what the problem could be. basiclly it will start and run for a little bit but it wiil die and not start again. it will not drive. any help would be great!!.
thanks
ben R
Old Nov 1, 2007 | 05:15 PM
Honda Sport's Avatar
you convert everything to obd2?
Old Nov 1, 2007 | 06:04 PM
xxmastermindxx's Avatar
Default Re: (Honda Sport)
tuned?
Old Nov 2, 2007 | 02:18 PM
redrusch's Avatar
yes everything has been converted. also it has the JR ECU flash or whatever they use when you install a kit. i suppos it could need a new tune. is that possible?
Old Nov 2, 2007 | 02:29 PM
prelude_93vtec's Avatar
Default Re: (redrusch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redrusch &raquo;</TD></TR><TR><TD CLASS="quote">yes everything has been converted. also it has the JR ECU flash or whatever they use when you install a kit. i suppos it could need a new tune. is that possible?</TD></TR></TABLE>
yes
Old Nov 2, 2007 | 06:13 PM
redrusch's Avatar
i have no expierence with superchargers. when its idealing or revving a little the supercharger is making a grinding noise. does this mean it is bad or is this how it sounds when it isent tuned right.??
Old Nov 2, 2007 | 06:52 PM
dagle's Avatar
when u got the JDM h22a, did u change the timing belt? maybe ur timings off
Old Nov 2, 2007 | 11:55 PM
redrusch's Avatar
hmm, i dont think so but i did have to take the end of the engine appart to put a crank position sensor in.
Old Nov 3, 2007 | 12:00 AM
JasonST's Avatar
Any cel's (check engine lights)? Was the engine running good before u put the s/c on it or did it always run badly?
Old Nov 3, 2007 | 11:38 AM
redrusch's Avatar
no there are no CEL's. also i have used a diagnostic tool on it a couple times and it says the crank position sensor is bad so i tested that and it is fine im sure of that. yes it was in brand new running condition before the supercharger was added.
Old Nov 4, 2007 | 01:03 PM
redrusch's Avatar
bump
Old Nov 4, 2007 | 02:26 PM
roflcopterdown's Avatar
describe the problems with how it runs. is it only the noise from the SC that is bad?
Old Nov 4, 2007 | 02:50 PM
redrusch's Avatar
it will start and run for a while but after a little bit the plugs get fouled out and it dies. when you put it at full throttle i will only go to about 4K RPMs. the reason i brought up the supercharger is because i think it isent getting enough air. the thing is that it was running great before i but the JDM motor in. the JDM motor has .6 more compression i believe, could this affect it this much.
Old Nov 5, 2007 | 02:20 PM
redrusch's Avatar
bump
Old Nov 5, 2007 | 03:12 PM
kb58's Avatar
Banned
No. the plugs getting fouled means too much gas. Is this setup using the FPR, fuel pressure regulator that came with the supercharger? What's your fuel pressure doing?
Old Nov 6, 2007 | 11:21 AM
redrusch's Avatar
yes im using the regulator that came with the charger. im not sure how to test pressure???
Old Nov 6, 2007 | 01:42 PM
NowABeliever's Avatar
i know you said you converted everything over but this sounds like a problem similar to one i had. The h22a uses peak and hold injectors while the obd2 h22a4 uses saturated injectors. You are using the right kind of injectors for your ecu correct?
1992-96 Prelude VTEC Peak and Hold 345cc
1997-up Prelude VTEC H22 Saturated 280cc
if you using the 345 cc h22a peak and holds with you obd2 ecu it will cuase this exact problem!!!!!
Old Nov 6, 2007 | 02:36 PM
kb58's Avatar
Banned
Default Re: (NowABeliever)
Good point about the injectors!
Old Nov 7, 2007 | 08:13 PM
redrusch's Avatar
ya i stripped the JDM block down before install and but the USDM intake manifold. etc. on it.
Old Nov 7, 2007 | 08:16 PM
ProjectBB6's Avatar
vacuum leaks?
Old Nov 7, 2007 | 09:39 PM
ludeboi121's Avatar
Default Re: (ProjectBB6)
double check the wiring to the ecu, bad wiring will cause it to die, which was what i had before. when you splice wire make sure you solder them. I recommend ditching that unit and go with hondata.
Old Nov 7, 2007 | 09:51 PM
98vtec's Avatar
moderator emeritus
Default Re: (ludeboi121)
there are two crank sensors...
did you get a CKP or CYP check engine light?
Old Nov 8, 2007 | 11:10 AM
flyrod's Avatar
Default Re: (98vtec)
plugged cat? map sensor not hooked up?
Old Nov 8, 2007 | 07:46 PM
redrusch's Avatar
when i tested it. it threw a CKP code so just for kicks i cut the wire that was from the supercharger and spliced into one of the 4 wires too the crank position sensors. when i did this it stopped trowing the code. if this makes sense explain it to me please. thanks for all your help thus fare, i want to get this basterd on the road!
BadhondaBAD!
Feb 21, 2014 11:14 AM
R.Thompson718
Mar 13, 2011 10:33 AM
wush
Apr 30, 2007 05:55 AM
