drive difference in 04 type-s and 06 type-s?
Old Nov 1, 2007 | 12:14 PM
dan12288's Avatar
Default drive difference in 04 type-s and 06 type-s?
okay i own a 04 rsx type s and i drove my friends 06 and the drive was much easier.... i noticed that my 04 felt really "torqy"(if thats a word) compared to the 06 type s... i loved the way the 06 felt compared to the 04... but why is it that it feels this way.. its mostly noticeable in low rpm and low speeds. mainly in 1st and 2nd gear...
Old Nov 1, 2007 | 12:23 PM
aemciv's Avatar
Default Re: drive difference in 04 type-s and 06 type-s? (dan12288)
Yeah I have an 03 and I drove my friends 06 and it is so much smoother through the rpm band. Seems like the 02-04 mainly have power above 6k and the 05-06 is more spread out. We ran them (I have a short ram intake and his is stock), and we were basically even. Seemed like I had a little more pull at higher speeds but prob due to the intake.
prose
Old Nov 1, 2007 | 02:41 PM
Todd00's Avatar
I said I don't want a title!
Shorter gear ratio and shorter tires on the 05-06. Also, slightly revised ECU tuning on the 05-06.
Old Nov 1, 2007 | 04:14 PM
risktypeS's Avatar
Default Re: drive difference in 04 type-s and 06 type-s? (Todd00)
Also the 05-06 have different cams then the 02-04. 05-06 have better cams then the 02-04 and that's prolly why it feels much smoother.
Old Nov 1, 2007 | 04:27 PM
Todd00's Avatar
Default Re: drive difference in 04 type-s and 06 type-s? (risktypeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS &raquo;</TD></TR><TR><TD CLASS="quote">Also the 05-06 have different cams then the 02-04. 05-06 have better cams then the 02-04 and that's prolly why it feels much smoother. </TD></TR></TABLE>
Honestly, that won't make much difference (if anything larger cams make things worse). The ECU tuning is what makes the 05-06 feel smoother.
Hondata flash on the 02-04 also does the same thing.
Old Nov 1, 2007 | 06:09 PM
risktypeS's Avatar
they only make it worse if you don't have an engine management to tune for the difference.. but i see what you're saying.
Old Nov 1, 2007 | 08:03 PM
mikestypes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">Shorter gear ratio and shorter tires on the 05-06. Also, slightly revised ECU tuning on the 05-06.</TD></TR></TABLE>
Yeah, the gearing is 15% shorter, so every gear in an 05-06 TypeS will have 15% more torque at the wheels just from this alone. Factor that in with a stiffer chassis, revised suspension tuning and more power and you get the better feeling car.
Old Nov 1, 2007 | 08:09 PM
Todd00's Avatar
Default Re: drive difference in 04 type-s and 06 type-s? (mikestypes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypes &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, the gearing is 15% shorter, so every gear in an 05-06 TypeS will have 15% more torque at the wheels just from this alone. Factor that in with a stiffer chassis, revised suspension tuning and more power and you get the better feeling car.</TD></TR></TABLE>
Also, don't forget that the 'reinforced' chassis come with 80 extra lbs. And, the 05-06 has 21lb 17" wheels compared to the 16lb 16" wheels on the 02-04. That in itself will make for a 'smoother' feel. Kind of what a heavy flywheel does...think inertia: in this instance it is basically defined as the tendency for matter to continue moving in a straight line. That = smoothness. Heavy wheel = more inertia.
Sounds trival, but it adds up.
killacairo911
Apr 28, 2010 09:15 PM
AznInvasion
Mar 22, 2008 09:56 AM
jdcdc5
Aug 23, 2007 12:56 PM
dixie Normas7
32
Jul 20, 2006 10:44 PM
GS-R Jay
17
May 25, 2002 11:12 AM
