91 R/T4wd Wagovan Da16a (Engine Troubles)
Old Oct 31, 2007 | 11:04 PM
Norcal510's Avatar
Default 91 R/T4wd Wagovan Da16a (Engine Troubles)
Hello All,
Im hoping someone could help me solve my problem with my R/T 4wd (stock motor) Wagon 6spd. Well the other day while getting off the exit my car shut off & wouldnt start. As I shifted out of gear the RPM started to drop & keept dropping until the motor was off. Right after the motor shut off the oil light & batt light came on. After getting the car towed home & someone suggesting to check the distributor. I realized the cap had something that had broke. I did a quick tuneup oil,sparkplugs,cap, rotor & new battery.
I test drove the car & it seemed fine but whenever I would get off the hwy on a slanted hill the RPM would drop & unless I jumped on the gas it would just keep dropping unitl the car shut off. Its still giving me oil & batt lights. It starts up but idles rough unless I gas it. Once started it works fine.
Someone told me Idle control unit. I clean that & it ran a bit better but still shuts off as discribed above. Someone also suggested map sensor, oil pressure?
Can someone help diagnose the problem & hopefully tell me what I need to do to get it fixed & running again.
Old Nov 1, 2007 | 06:53 PM
Norcal510's Avatar
Default Re: 91 R/T4wd Wagovan Da16a (Norcal510)
Suggestions ? ? Anyone ? ?
Old Nov 1, 2007 | 11:04 PM
MooseRex's Avatar
if it only happens on a hill, then you could have an intermittent short or open on one of those sensor wires. Get the car running and jiggle the sensor connectors and any other connectors under the hood. it's a weird problem, I can't think of what else it may be.
Old Nov 1, 2007 | 11:57 PM
Fezzie's Avatar
Default Re: 91 R/T4wd Wagovan Da16a (MooseRex)
mabe the distributor is going bad
Old Nov 14, 2007 | 08:40 PM
Norcal510's Avatar
how can I check if the distributor is going bad? Would any DA motor distributor work with my da motor?
Thanks again
PinoyDelS0l
Dec 25, 2018 10:45 AM
NorthWestCB7
Jan 7, 2018 04:04 PM
vietdragontekx
Jan 29, 2008 03:45 PM
austinkli
Jan 16, 2008 02:29 PM
