crx w/ b18a no start trouble
Old Oct 31, 2007 | 10:14 PM
bboy_mikey's Avatar
Default crx w/ b18a no start trouble
my cars been dead for a long time and iv been lazy to fix it when i got the chance i replaced all these parts.
new battery, alternator, fuel filter, replaced grounds bolts, checked my timing belt, checked for spark, my fuel pump is still goes off when i turn the key, replaced the starter, distributor, spark plugs,
i think it might be a wireing problem cuz everything connected to the ecu is screwed up! and my friend says i should replaced the spark plugs even tho we're getting spark, i brought it to a shop and they called me a week later saying they cant fix it so i wasted money to get my car towed to a shop and now i got to tow it back. the last fix up i did to my car was replace the distributor and thats when my car started but if i didnt keep my foot on the gas the car would die any thoughts of what this problem might be?
Old Oct 31, 2007 | 10:59 PM
oodie's Avatar
Default Re: crx w/ b18a no start trouble (bboy_mikey)
Codes?
Old Nov 1, 2007 | 07:48 PM
MoreBoost!'s Avatar
Default Re: crx w/ b18a no start trouble (oodie)
it could be a number of things. i worked on a few cars with this problem. water in the gasoline, bad timing, pcv valve not pluged in, idle air control valve bad. u might be right about the bad wiring but these are jus a few example to look out for before u waste more money sending it to another shop that might not even fix it for u
Old Nov 2, 2007 | 04:54 PM
bboy_mikey's Avatar
hey how would water get into my gasoline? eveporated moisture? gahh i dont want to get rid of this car i'll keep this forum updated
Old Nov 8, 2007 | 01:44 PM
bboy_mikey's Avatar
hey i just recieved a complete wiring harness off a 93 integra, it should fit in my crx right? i never swapped out a wiring harness befor, i thought it would be easy until my friend gave me the whole harness for the dash lights and engine ect. so yeah is it pretty easy looks to me like its just plug and play what do you guys think?
Old Nov 8, 2007 | 11:15 PM
bboy_mikey's Avatar
Old Nov 9, 2007 | 02:18 AM
hcpbiker1's Avatar
Default Re: (bboy_mikey)
NO that harness wont even fit...
and was the car(crx) a dx model?
if so did you covert the wiring harness?
and what ecu are you running?
check your map sensor. and tps sensor
somtimes people plug them into each other (wrong clip for the wrong sensor)
i think that is code 7 for tps and code 4 for map sensor...
Old Nov 11, 2007 | 04:04 PM
bboy_mikey's Avatar
hey i dont even know what model it is. it just says SI on the back of the car but i know for sure it aint an SI. my car title dosnt even say what model it is it just says crx civic its either a dx or a hf and the guy who owned the car did all the wiring but its a freakin mess!! what wiring harness should i get then if the integra dosnt fit. a 91 ef si wiring harness? the ecu im running is the stock crx ecu i just wanna get a new wiring harness and make the wiring look a little better than it is now i havnt check the map sensor yet or tps sensor i'll look it up as soon as i can tho
Old Nov 12, 2007 | 09:59 AM
bboy_mikey's Avatar
anybody know what wiring harness i should be getting for a crx with a b18 ls?
Old Nov 12, 2007 | 01:32 PM
bboy_mikey's Avatar
well i just told my friend the wiring harness he gave me wont fit and he said i need a obd1 ecu off a teg. so now im gonna order a ecu off that car is everything still gonna connect together? lemme know if anybody dissagrees
Old Nov 12, 2007 | 09:12 PM
bboy_mikey's Avatar
any suggestions?
Old Jan 10, 2008 | 07:19 PM
b18hondahb's Avatar
first of all u need a hf or si harness and just get a used teg ecu make sure u have the wire s pluged up right and the hoses athe same way my car wouldnt start because the guy before me chopped the harness in places and just twisted them together hella gay. so check that what codes r u flashing?
089JAY
Jun 4, 2013 04:06 PM
93daintegra
Sep 16, 2008 01:21 PM
bmxbikes
Jul 13, 2007 07:27 PM
Groove_D
Dec 23, 2005 02:00 PM
