Suspension & Brakes Theory, alignment, spring rates....
undecided
Old Oct 31, 2007 | 09:18 PM
shotgun2224's Avatar
Default undecided
im plannin on goin with sum Function & Form type II full coilovers with sum blox LCAs and blox camber kits with an ASR lower rear brace but im not sure wut kind of sway bar i should use... any ideas?
Old Nov 1, 2007 | 01:27 AM
BlueIntegraBoy's Avatar
Default Re: undecided (shotgun2224)
If you are getting an ASR brace, might as well buy an ITR rear sway.
Old Nov 1, 2007 | 04:11 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
and don't waste money on camber kits. With a good alignment they're really not needed. Just make sure to rotate your tires every 5K miles like you should.
Old Nov 1, 2007 | 04:28 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">and don't waste money on camber kits. With a good alignment they're really not needed. Just make sure to rotate your tires every 5K miles like you should.</TD></TR></TABLE>
exactly, my camber is 2.2 and 1.4 and i have no tire wear.... i did my own alignment and just used washers in the rear to pull it in some.... plus you want camber as it will handle better in turns!
but i would just go ahead and get a itr rear bar while your at it.. they sell the kit wit brace.
Old Nov 1, 2007 | 05:56 AM
Dackonn's Avatar
Default Re: (B16B_coupe)
yeah just buy the combo package of the ASR brace w the 23mm(i think thats the size) rear swaybar
Old Nov 1, 2007 | 11:55 PM
where could i get that kit?
Old Nov 3, 2007 | 02:25 PM
bump
Ron M
Apr 3, 2008 06:33 AM
Scotty Dosent Know
Suspension & Brakes
Nov 30, 2005 12:19 PM
Dooley
Suspension & Brakes
Oct 7, 2005 08:28 PM
wickedEM1
Suspension & Brakes
May 26, 2005 10:22 AM
LX4CYL
19
Nov 1, 2004 11:53 AM
