Bosch LSU4.2 sensor connector/extension cable?
Old Oct 31, 2007 | 07:40 PM
HiProfile's Avatar
Default Bosch LSU4.2 sensor connector/extension cable?
Does anyone know a place I can get the male-end connector thats on a Bosch LSU4.2 wideband sensor, or an extension cable for this sensor? I'm one connector away from bringing my LC-1 into the cabin so it doesn't bounce around the engine bay.
BTW a dead sensor's connector would work too... Anyone about to throw one out?
Old Oct 31, 2007 | 09:44 PM
dbiker207's Avatar
Default Re: Bosch LSU4.2 sensor connector/extension cable? (HiProfile)
how about this 18ft cable instead of the stock 10ft one? http://cgi.ebay.com/ebaymotors...ZWD1V
Old Nov 1, 2007 | 06:48 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Bosch LSU4.2 sensor connector/extension cable? (dbiker207)
He is talking about the LC-1 not the LM-1 so that cable will not work. I would just contact innovate and buy one separately. I'm sure they would sell you one. Good guys over there.
It sucks because I had a dead (smashed) sensor that I gave away with a DP not too long ago.
Old Nov 1, 2007 | 03:48 PM
HiProfile's Avatar
Default Re: Bosch LSU4.2 sensor connector/extension cable? (White Smoke)
For $49 I'd rather cut the connector off my oily spare sensor. Thanks for the idea though, I've just not found any sensor-only extension. I don't know why not, since the LC-1 has to be less than 24" from your exhaust pipe w/o an extension...
bump
Old Nov 1, 2007 | 07:20 PM
i my honda
Global Mod
Where is your sensor mounted? I have an LC1 in cabin. Ran it through the OEM hole.
Old Nov 1, 2007 | 08:35 PM
HiProfile's Avatar
OEM hole?
I think you're confusing my obd1 & obd0 cars with an OBD2 car that has a useless 2nd sensor, and a turbo kit that puts the wideband in that spot. On my coupe, it came with a DC header, and that used an extender for the O2 to behind the motor. 'Stock' is through the engine harness. My sedan was basicly the same, as it was a DPFI harness melded with a Z6 harness for the Z6 motor.
On my sedan it's near the oil filter, on my coupe its in the downpipe a few inches above the clutch slave cylinder. Both have AC, both have a fat Hypalon 1/0 cable through the 'extra' hole in the firewall for battery relocation.
Old Nov 1, 2007 | 08:55 PM
i my honda
Global Mod
I'm not confused, just saying thats were I run mine. Drilling a hole somewhere on the tunnel or lower fire wall is not a big deal; then you can mount it in the cabin.
AllMotorLudeSi
Jun 9, 2012 06:24 PM
rolledthatho
15
Jan 26, 2011 07:52 PM
nwstreets
Northwest (Sales)
Nov 10, 2010 08:05 PM
psv4878
Engine Management and Tuning
Aug 19, 2010 09:48 PM
civicEXtreme
Oct 31, 2005 01:24 AM
