doe's anybody know how to get integra seats to fit a 91 crx?
Old Oct 31, 2007 | 07:11 PM
seanjamesef9's Avatar
Default doe's anybody know how to get integra seats to fit a 91 crx?
just got some integra seats for my 91 rex they are out
of a94 integra but the brackets are completly defferent
doe's anybody know how to get them to fit?
Old Oct 31, 2007 | 07:15 PM
STREETWERKZ's Avatar
Default Re: doe's anybody know how to get integra seats to fit a 91 crx? (seanjamesef9)
wow, you misspelled does twice.
most common way to make them fit is to swap the rails from your stock seats to the integra seats.
Old Oct 31, 2007 | 08:41 PM
Default Re: doe's anybody know how to get integra seats to fit a 91 crx? (STREETWERKZ)
my bad on the spelling but do you have to do any drilling or welding?
Old Nov 1, 2007 | 12:52 PM
turkishEF's Avatar
Like werkz said, use your crx rails. You will have to drill 2 of the holes. Just to extend them 3/4 inch or so. I used a dremel.
Also, since the teg seats will place the rails a little wider, you will need to make some metal tabs or something to mount to stock locations. Or you can drill into the floor i suppose.
Old Nov 2, 2007 | 06:38 AM
fastcrvi's Avatar
you can drill out stock welds and separate the the sliding brackets, one side of integra brackets per seat will unbolt, the other has to be drilled out the possibly redrilled to line up with crx rails, even after thats done integra seats will be a bit higher, if you're 6.2" height that may be a problem unless you recline the seat back.. as for drilling holes for wider integra seats, you can thread them but it won't hold very much.. you have to use locknuts unless you weld it from behind.. you will need to make some type of opening behind in order to secure locknut unless theres a way to reach..
Old Nov 2, 2007 | 06:59 AM
Trakhor's Avatar
Torque Junkie
I helped another guy on here do this a while back. We could only lign up one hole. we used that and made "extensions" if you can call them that to get the rails to work. There was tons of fabbing and welding involved. He is a short person compared to me so it worked good for him.
I'm about 6'2" and I could not do it. Be prepared for that if you are on the taller side. Part of the problem is that the CRX seats are not suspension seats like the Teg's. Suspension seats are deeper/taller in the seat bottom due to being suspension style.
Modified by Trakhor at 8:32 AM 11/2/2007
Old Nov 2, 2007 | 05:33 PM
1 Fly SI's Avatar
Default Re: doe's anybody know how to get integra seats to fit a 91 crx? (Trakhor)
I just put them in my girls crx the other day. I swapped the seat pans.
Old Nov 2, 2007 | 05:58 PM
loudandlow's Avatar
Default Re: doe's anybody know how to get integra seats to fit a 91 crx? (1 Fly SI)
CAN YOU PLEASE STOP SAYING DUMBASS THINGS ABOUT YOUR GIRLS CRX IN EVERY SINGLE THREAD PLEASE?
Old Nov 2, 2007 | 06:04 PM
1 Fly SI's Avatar
Default Re: doe's anybody know how to get integra seats to fit a 91 crx? (loudandlow)
What the expletive do you have *******. I know what I am talking about. Read and search. Switch the seat pans. It works. I have had 14 crx's and I guarentee you I know more about them then you.
Old Nov 2, 2007 | 06:05 PM
loudandlow's Avatar
i'm sorry, can we kiss and make up?
Old Nov 2, 2007 | 06:28 PM
1 Fly SI's Avatar
Seat pans were swapped. Every bolt lined up perfect. No modifying needed. Don't call me out again.
Old Nov 2, 2007 | 06:57 PM
loudandlow's Avatar
rusty brackets
Old Nov 2, 2007 | 11:18 PM
1 Fly SI's Avatar
Yep. It is a daily driver.
Old Nov 4, 2007 | 05:43 PM
b18c4g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Fly SI &raquo;</TD></TR><TR><TD CLASS="quote">Seat pans were swapped. Every bolt lined up perfect. No modifying needed. Don't call me out again.
Those aren't dc seats though are they?
Old Nov 4, 2007 | 09:43 PM
gsrpedro's Avatar
yes they are.....and i have gsr seats on my ef and they bolt on perfect witout modifications
Old Nov 12, 2007 | 01:22 PM
[Ennis_D]'s Avatar
Default Re: (gsrpedro)
Anyone have a write up, or a link to a write up for swapping seat pans? I saw a thread about it on page 1 w/ 90-91 seats into 88hb but the pics seem dead. Also, after the seat pan swap, do the integra seats seem to sit higher than the stock seats did? Any help/input would be greatly appreciated!
TIA
Old Nov 12, 2007 | 01:29 PM
ef yu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c4g &raquo;</TD></TR><TR><TD CLASS="quote">
Those aren't dc seats though are they?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpedro &raquo;</TD></TR><TR><TD CLASS="quote">yes they are.....and i have gsr seats on my ef and they bolt on perfect witout modifications</TD></TR></TABLE>
they are 92-93 integra seats by the looks of it
Old Nov 13, 2007 | 12:31 PM
[Ennis_D]'s Avatar
Default Re: doe's anybody know how to get integra seats to fit a 91 crx? (ef yu)
Any help/info to my question? Thanks guys!
Old Nov 13, 2007 | 07:48 PM
1 Fly SI's Avatar
Default Re: doe's anybody know how to get integra seats to fit a 91 crx? ([Ennis_D])
his link is good.
https://honda-tech.com/zerothread?id=1062869
Pretty much the same way I did the integra seats in my crx. They don't seem higher.
Old Nov 13, 2007 | 08:02 PM
black0hatch's Avatar
those are da seats not dc
Old Dec 31, 2007 | 04:30 AM
jdm_crx_ racer's Avatar
well my advice is if you still have the stock seats that came with the rex then jus switch the brackets from the rex to the integra seats then that should do it
Old Dec 31, 2007 | 05:30 AM
CRX Toad's Avatar
Default Re: doe's anybody know how to get integra seats to fit a 91 crx? (jdm_crx_ racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_crx_ racer &raquo;</TD></TR><TR><TD CLASS="quote">well my advice is if you still have the stock seats that came with the rex then jus switch the brackets from the rex to the integra seats then that should do it</TD></TR></TABLE>
My advice is to look at the dates on the threads. As this is the SECOND one that you have brought back from the dead
And your info is terrible and doesn't work because the seat bottoms are different don't answer thread and post stuff when you have no idea.
Just2Fast
Jul 6, 2006 09:00 AM
p3t3rxp4n
May 7, 2006 04:39 AM
91sleeper
31
Apr 10, 2004 09:07 PM
IntegraFanatic
Mar 25, 2004 01:46 PM
dustin
Sep 6, 2001 02:40 PM
