LS Swap...Need Help Guys..
I'm swapping in a 2000 LS motor into my 94 civic si.. I'm having trouble with the wiring.. Can anyone help me? I have my 94 si engine harness but the plugs don't fit the alternator for the LS motor and SI P28 ecu? Can anyone tell me where I can get the plug for the alternator? I also have a 94 LS ecu(P75) and the engine harness.. BUt I still run to the same problem.? Is there any alternative routes to do this swap? Thanks guys..
The alternator plug is different??
Wouldnt the dizzy plug be different? going from a 2 plug obd1 to a 1 plug obd2. For the ecu, your going to need either a obd1-obd2 jumper, a obd1 ecu chipped for the b18b, or to convert the b18b to obd1 and use a obd1 p75
welding and fab forum? You retarded?
Anyway, you're dealing with an obd2 alternator, so it's a square plug instead of a round one. You can swap plugs, get a jumper harness (some alternators come with them and are universal obd1/obd2) or you can get an obd1 alternator.
But like the other guy said, do you have an obd1 distributor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lee_eg6si »</TD></TR><TR><TD CLASS="quote">I'm swapping in a 2000 LS motor into my 94 civic si..</TD></TR></TABLE>
Sooooooo, shouldn't this be in the Hybrid forum?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top Ramen »</TD></TR><TR><TD CLASS="quote">
Sooooooo, shouldn't this be in the Hybrid forum?</TD></TR></TABLE>
You would think so....
u can use an obd2 distro for a obd1 swap right?all u would have to do is switch the plugs like the alt. right?
never really tried to use obd2 parts in my swaps.
sorry to add to the mayhem.
project91crxsi
Oct 16, 2011 12:49 PM
bboylito
13
Apr 15, 2005 03:46 AM
