99-01 si wheels on 88 crx
Old Oct 31, 2007 | 02:21 PM
SFlCrx's Avatar
Default 99-01 si wheels on 88 crx
2 questions really how will the wheels fit and can i run 205/50/15 falken azenis rt 615's on theese wheels or is the rim not wide enough. thanks
Old Nov 1, 2007 | 07:20 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 99-01 si wheels on 88 crx (SFlCrx)
First, there's no such thing as a 2001 Civic Si. So you're talking about the 15x6 wheels used on the '99-00 Civic Si.
Yes, they can be mounted on those rims. Falken approves the 205/50-15 RT-615 for mounting on rims 5.5-7.5 inches wide.
I don't know if the offset or spoke design of this rim will work on your car.
If this is for autocross or track use, the RT-615 in 205/50-15 is an excellent choice. For a daily driving street tire, 205/50-15 in general, and the RT-615 in this size in particular, are a bit big for your car; it will throw off your speedometer and odometer, and make your car accelerate slower (like using taller gears). For these reasons, 195/50-15 is usually a better size for a CRX for street use.
import2nr88's Avatar
Common wheel/tire choice.
They will fit just fine and look pretty good as well.
Old Nov 1, 2007 | 02:50 PM
SFlCrx's Avatar
Default Re: 99-01 si wheels on 88 crx (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">First, there's no such thing as a 2001 Civic Si. So you're talking about the 15x6 wheels used on the '99-00 Civic Si.
what is the off set on these wheels anyway. ideal off set for my car is 38-40 right? i know these tires are too wide for my car. i had 195/50/15 bridgestones re-01r on my slipstreams but got stolen . this is for autocrossing i need new rims and tires fast so i was just going to pick up these si wheels from a friend and pick up some falkens down the street from my dealership. do you think this wheel and tire set up would be alright cause i think it will definetly be better then my dd wheels and tires es100 195/50/15s
DeLucia
Feb 17, 2011 11:43 AM
2harsh4me
Oct 1, 2007 12:20 AM
stickyfingers
Mar 10, 2004 07:03 PM
keebler65
Dec 15, 2002 10:51 AM
boonacka
16
Nov 14, 2002 08:40 AM
