Injectors???
Old Oct 31, 2007 | 12:00 PM
ej1252's Avatar
Default Injectors???
Is there a difference between saturated and peak/hold injectors???
Is it true that saturated is for N/A and peak/hold is for FI???
Im turbo and wanna go up to 550cc, which would i buy???
Can someone give me some info???
Old Oct 31, 2007 | 12:06 PM
b18bturbo's Avatar
Default Re: Injectors??? (ej1252)
yes there is major difference between peak nad hold and saturated.
the major difference is within the ohm its takes to fire the coil within the injector. All an injector is a coil.
The coil in saturatd usually in the range of 14-16ohms while the peak and hold is 2-4ohms
honda stock ecu is based on a saturated driver.
If you can get 550cc saturated then that will be plug and play with a good chip tune.
Old Oct 31, 2007 | 12:11 PM
all-mtr-teg's Avatar
Where are you gonna get your tune?
Old Oct 31, 2007 | 01:40 PM
ej1252's Avatar
Default Re: Injectors??? (b18bturbo)
o i see, so which ones do i get since i have a p28 on chrome and turbo:
saturated or peak/hold injectors???
Old Oct 31, 2007 | 01:41 PM
ej1252's Avatar
Default Re: Injectors??? (all-mtr-teg)
the place is called Batlground Engineering
Old Oct 31, 2007 | 02:28 PM
b18bturbo's Avatar
on stock p28 you need to get saturated unless you have injector driver or a resistor box wired in.
Old Oct 31, 2007 | 02:37 PM
ej1252's Avatar
o i see, so im gon get peak/hold, thanks
Old Oct 31, 2007 | 03:59 PM
where are they located?
Old Oct 31, 2007 | 04:00 PM
ej1252's Avatar
Smyrna, GA
Old Oct 31, 2007 | 04:15 PM
b18bturbo's Avatar
no that is incorrect you need saturated not peak and hold peak and hold is 2ohm-4ohm will not work unless you have resistor box or some injector driver.
Old Oct 31, 2007 | 04:39 PM
ej1252's Avatar
oo ok, i see, thanks to all
cameron4776
Sep 22, 2007 05:33 PM
nolicense526
Jul 31, 2007 06:17 AM
swt_666
May 16, 2007 09:33 PM
dkdjlf
Sep 19, 2003 02:31 AM
T60-1VTECrex
Mar 3, 2003 04:52 PM
