Remove CRV factory 6 CD changer
On the same subject as the thread below, does anyone know where I can find instructions on how to remove the factory stereo from the dash to install my ipod integration cable? Is this simple enough for an amateur to do?
remove two screws under center dash vent pull out on the trim and remove 4 8mm bolts make sure you know your radio code if not u can take the radio to honda and they can get you the code.
danomatic93
12
Feb 7, 2013 07:50 AM
GetawayInMoscow
May 13, 2005 08:38 AM
