Anyone running an eBoost2? I have a few questions...
I'm about to wire this up but I have a few questions before I go ahead.
As you can see, it states the White wire is to be connected to an auxiliary relay. Can I use the stock ACC relay for this, which would be the same that only turns on the audio system? Or do I need to purchase another relay?
The Green and Orange wire state that they need to be switched to a grounded source. Can I just ground them like I do any other ground wire, or do I have to absolutely put a switch on them? If so, what kind of switch are they talking about, and for what purpose?
Any help would be greatly appreciated, so please let me know!
switched to ground means power "IN", to switch, and power "OUT" of switch goes and gets bonded to any part of your metal chasis or frame. If its anywhere near your center counsil the metal cross beam that your radio gets grounded too would be fine (or anything similar if you know what I mean).
I hear electric forced intake is garbage though. Let everybody know the results if you can get it Dynoed.
hatchinprogress
20
Aug 14, 2004 05:50 PM
