what pistons/rods/sleeve company would you recomend? (boosted)
Old Oct 31, 2007 | 05:28 AM
eg64u's Avatar
Default what pistons/rods/sleeve company would you recomend? (boosted)
I plan on rebuilding a gsr block and using the type r head and transmission i currenntly have. I want fully built buttom end. Im planning on just running very conservative tuning on s300. Basic goals are to get around 350whp and be able to drive it as often as possible without having to worry about to many issues. top end would be totally stock type r head for now. So what do you guys think. Somethign that is effective yet not overkill for what im doing.
let me know
thanks in advance
Old Oct 31, 2007 | 05:36 AM
Schister66's Avatar
Man U FTW
-stock sleeves
-CP 9.8:1 pistons
-Eagle H-beam rods
-OEM Honda bearings
-ARP headstuds
there is no need for aftermarket sleeves for 350whp...hell, theres hardly a need for anything other than a bone stock B series for that power goal...check my sig...thats on a stock GSR block
Old Oct 31, 2007 | 05:58 AM
MeanGreenMachine's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">-stock sleeves
-CP 9.8:1 pistons
-Eagle H-beam rods
-OEM Honda bearings
-ARP headstuds
there is no need for aftermarket sleeves for 350whp...hell, theres hardly a need for anything other than a bone stock B series for that power goal...check my sig...thats on a stock GSR block</TD></TR></TABLE>
Old Oct 31, 2007 | 07:19 AM
morgan@synapse motorsport's Avatar
-CP 9.8:1 pistons
-Eagle H-beam rods
-OEM Honda bearings
-ARP headstuds
j/k schister is right sleeving isnt necessary at that level. might as well throw in a new oil pump, water pump timing belt while your at it. we also clean and drill the cranks on our shortblock builds.
Old Oct 31, 2007 | 07:24 AM
DC2_117's Avatar
-CP pistons
-Eagle H-beam rods
-ACL bearings
-ARP headstuds
As far as sleeving I like ERL, But I also like Golden Eagle just depends on what your buget is like. IMO
Old Oct 31, 2007 | 07:28 AM
Schister66's Avatar
Man U FTW
I just want to throw this out there for a discussion...
ACL Bearings VS OEM Honda Bearings...which is better for a car thats going to see mainly street use?
Old Oct 31, 2007 | 11:53 PM
'94civic b16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">I just want to throw this out there for a discussion...
ACL Bearings VS OEM Honda Bearings...which is better for a car thats going to see mainly street use?</TD></TR></TABLE>
The ones that give you the proper clearances.
Personally I used the ACL bearings because they were about half the price and they allowed for perfect clearances
Old Nov 1, 2007 | 09:21 AM
champLSinteg's Avatar
Default Re: ('94civic b16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’94civic b16 &raquo;</TD></TR><TR><TD CLASS="quote">
I prefer OEM. I used k-series main bearings on my motor because they were much cheaper and work! Total of around $110 in bearings.
Old Nov 1, 2007 | 10:36 AM
Schister66's Avatar
Man U FTW
...the reason im asking is because with any luck i'll be at least starting an engine build by next fall/winter. Thanks
Old Nov 1, 2007 | 10:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">...the reason im asking is because with any luck i'll be at least starting an engine build by next fall/winter. Thanks</TD></TR></TABLE>
are you looking to max out that turbo now?
oldskoolracer
Jan 7, 2009 01:40 PM
crx87
Dec 8, 2008 11:08 AM
all-mtr-teg
Mar 17, 2007 05:49 AM
93supercoupe
May 27, 2005 01:28 AM
