took off muffler.....got a question
Old Oct 30, 2007 | 06:01 PM
20ls01's Avatar
Default took off muffler.....got a question
does it reduce gas mileage? or have any other side affects besides being louder?
i did search and it said there wont be any back pressure. what does this mean? and whats the effects of no back pressure?
Modified by 20ls01 at 7:20 PM 10/30/2007
Old Oct 30, 2007 | 06:13 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: took off muffler.....got a question (20ls01)
it smells really bad and it attracthes cops
Old Oct 30, 2007 | 06:26 PM
well it depends where you live, when i lived in cali i always had stock exhaust cuz cops were always on loud cars and exhausts but now i live in NC and i sumtimes cruz with open header and cops dont care so depends in ur location as well
Old Oct 30, 2007 | 06:27 PM
Default Re: took off muffler.....got a question (DOHCgarage919)
back pressure i think will lower ur tq not sure but when i had an exhaust cut out on my civic and when id open the header up i wud have lots of top end but my bottom end was weak like no tq
Old Oct 30, 2007 | 06:28 PM
polishedturd's Avatar
I like PIE
i took the muffler off my gsr once with a test pipe in place of the cat and vtec sounds lovely! any other time its just annoying.
Old Oct 30, 2007 | 06:31 PM
The purpose of the car’s exhaust system is to evacuate gases from the combustion chamber quickly and efficiently. The exhaust gasses do not flow in a smooth stream. Because the gasses are vented at each opening of the exhaust valves there is a pulse of gasses from each cylinder. Just put you hand near the exhaust tip and you will feel the pulses. In a MX-5 engine there are four pulses per cycle
The exhaust gasses produce a positive flow in the exhaust pipe. Backpressure can be likened to resistance to the positive flow of the exhaust stream. Taken to its extreme backpressure can lead to a reversal (albeit momentarily) of the exhaust stream.
Old Oct 30, 2007 | 06:33 PM
Backpressure is necessary at lower RPMs to make the most efficient
cylinder filling
basically when i had my car open header it had less tq but when you reach vtec it pulls hard but you need back pressure
EK FLY
16
Oct 6, 2006 12:27 PM
99BlackHatchSiR
Jun 26, 2006 02:56 PM
Jeff92NY
14
Oct 29, 2003 12:09 PM
onyx00
May 23, 2002 06:57 AM
Dawsonb17a
Jun 15, 2001 07:56 PM
