Whats the diiference if any between a H22a1 and H22a4 Head?
Old Oct 30, 2007 | 04:14 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Whats the diiference if any between a H22a1 and H22a4 Head?
Besides one being OBD 1 and the other OBD 2
Thanks in advance
Old Oct 30, 2007 | 04:25 PM
Acidcrakker's Avatar
Default Re: Whats the diiference if any between a H22a1 and H22a4 Head? (I got the CD5 Jeebies!)
More aggressive cams
Old Oct 30, 2007 | 04:29 PM
Default Re: Whats the diiference if any between a H22a1 and H22a4 Head? (Acidcrakker)
in which head? I have an H22a1 head for sale and I'm selling it to a guy that has a warped head on a H22a4 and I'm just trying to see if there are any major or minor obsticals in simply swapping the head.....never done a head swap so just searching for clarifacation...
thanks for the quick response
Old Oct 30, 2007 | 04:41 PM
The a4 has more aggresive cams and has about 30 more Hp.
Heres a list of H motors and their lists
H23A1 DOHC NON VTEC UDSM 160 HP
H23A DOHC VTEC JDM 200 HP JDM
H22A JDM BASE MODEL 200 HP
H22A8 EDM BASE MODEL LUDE LIKE THE H22A4
H22A EURO R 217 HP JDM
H22A LUDE TYPE S 220 HP JDM
H22A7 EDM ACCORD TYPE R 212 HP
H22A4 195-200HP USDM LUDE
H22A1 USDM LUDE 190 HP
Old Oct 30, 2007 | 04:57 PM
street_ride14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">The a4 has more aggresive cams and has about 30 more Hp.
H22A1 USDM LUDE 190 HP</TD></TR></TABLE>
You are wrong all over the place.
Old Oct 30, 2007 | 05:21 PM
xxmastermindxx's Avatar
Default Re: Whats the diiference if any between a H22a1 and H22a4 Head? (street_ride14)
well, the list of motors and ~specs is about right
i don't see where you pulled that "30 more Hp" line from, if you looked at your own list, you'd see that
Old Oct 30, 2007 | 05:40 PM
Default Re: Whats the diiference if any between a H22a1 and H22a4 Head? (xxmastermindxx)
Opp my bad, I still seem to think the a4 has 220 hp and the a1 has 190 hp.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmastermindxx &raquo;</TD></TR><TR><TD CLASS="quote">
i don't see where you pulled that "30 more Hp" line from, if you looked at your own list, you'd see that </TD></TR></TABLE>
Old Oct 30, 2007 | 05:45 PM
h23vtecpowered's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmastermindxx &raquo;</TD></TR><TR><TD CLASS="quote">well, the list of motors and ~specs is about right
yea
Old Oct 30, 2007 | 11:50 PM
MLBZ521's Avatar
I do not believe there is any difference..
I just searched the Official Camshaft Thread and couldn't find H22A4 Cam Specs, but found the H22A1 Specs.. To late to search anymore for me.
I don't see the 30hp difference between an A1 and A4 either...
Old Oct 31, 2007 | 07:13 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Opp my bad, I still seem to think the a4 has 220 hp and the a1 has 190 hp.</TD></TR></TABLE>
Dude....I know youre new but if youre not sure about something don't post it.
Heads are interchangeable....go for it!
Acidcrakker= -2%
Old Oct 31, 2007 | 07:25 AM
Finest's Avatar
Default Re: Whats the diiference if any between a H22a1 and H22a4 Head? (MLBZ521)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">I don't see the 30hp difference between an A1 and A4 either... </TD></TR></TABLE>
Unless you're talking about the Type S motor, which has a slightly higher compression and more aggressive cams.
Old Oct 31, 2007 | 07:58 AM
NirVTEC's Avatar
Default Re: Whats the diiference if any between a H22a1 and H22a4 Head? (Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">
Unless you're talking about the Type S motor, which has a slightly higher compression and more aggressive cams. </TD></TR></TABLE>
Its also NOt tagged an A4.
Higher compression
More agressive cams
Different intake and intake manifold
Better port work
Larger throttle body(?)
Old Oct 31, 2007 | 08:36 AM
Sam_J's Avatar
Default Re: Whats the diiference if any between a H22a1 and H22a4 Head? (::NirVTEC::)
The one difference I can think of is the type of LMA used in each head
h22a1's and earlier model h22a4's use a cylinder type lma, h22a4s 1999+ use a spring type design which is much much cheaper to replace.
h22a1 lifter on left, 99+ h22a4 lifter on right
Old Oct 31, 2007 | 09:48 AM
Televator's Avatar
Also the Euro R head has matched intake ports and runners.
Here: one of my fave threads on it: https://honda-tech.com/zerothread?id=1995637
I really recommend it for visual reference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam_J &raquo;</TD></TR><TR><TD CLASS="quote"> The one difference I can think of is the type of LMA used in each head
h22a1 lifter on left, 99+ h22a4 lifter on right </TD></TR></TABLE>
Nevermind. I found everything I need to know. I had just fallen out of bed, and was temporarily "search impaired." LOL!
Modified by Televator at 1:37 PM 10/31/2007
Modified by Televator at 1:38 PM 10/31/2007
Old Oct 31, 2007 | 12:19 PM
dominican luder's Avatar
So if you put a type-s head on a H22A4 block, will the compression drop or will it stay the same? Basicly, is the higher compression do to the pistons or the legth of the head?
Old Oct 31, 2007 | 12:27 PM
The Captain's Avatar
Default Re: Whats the diiference if any between a H22a1 and H22a4 Head? (dominican luder)
i know for certain the pistons are different, you can purchase type s pistons, but the head may also have something to do with it.
Old Oct 31, 2007 | 02:33 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dominican luder &raquo;</TD></TR><TR><TD CLASS="quote">
So if you put a type-s head on a H22A4 block, will the compression drop or will it stay the same? Basicly, is the higher compression do to the pistons or the legth of the head?</TD></TR></TABLE>
Pistons.
Old Oct 31, 2007 | 05:01 PM
94Vtecluder's Avatar
Default Re: Whats the diiference if any between a H22a1 and H22a4 Head? (Televator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam_J &raquo;</TD></TR><TR><TD CLASS="quote">The one difference I can think of is the type of LMA used in each head
OHHHHHHHHHH!!!!!
He just said shut up! Well basically.
Old Oct 31, 2007 | 05:31 PM
thanks for all the extra info guys..just wanted to know about the interchangeability? of swappign the head..I basically had an answer but wanted to make sure....
Drinks on me
LUDEcidDream
Feb 21, 2011 06:59 PM
d_SUPAl1l
Nov 13, 2006 05:29 AM
jmcclell
Jun 3, 2004 10:53 AM
DaGod
Jun 9, 2002 10:55 AM
