Bad Piston Rings
Old Oct 30, 2007 | 02:51 PM
r3v da t3g's Avatar
Default Bad Piston Rings
So I guess my piston rings are bad on two of the pistons. Looks like its time for a rebuild? how much does rebuilding usually cost? i was quoted 2400. What does the rebuild consist of to make it that much? the boring and honing? oversize pistons and rings? bearings?
Old Oct 30, 2007 | 02:52 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Bad Piston Rings (r3v da t3g)
**** for 2400 you can get a nice low mileage swap or build something decent....i hope that 2400 wasn't a quote for a stock rebuild
Old Oct 30, 2007 | 03:58 PM
r3v da t3g's Avatar
Default Re: Bad Piston Rings (GRAF-FITI)
Would i be okay with without boring or honing the head or block? just slap on some new piston rings, bearings,gaskets???
Old Oct 30, 2007 | 04:01 PM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3v da t3g &raquo;</TD></TR><TR><TD CLASS="quote">Would i be okay with without boring or honing the head or block? just slap on some new piston rings, bearings,gaskets???</TD></TR></TABLE>
It depends how worn the cylinder walls are...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">**** for 2400 you can get a nice low mileage swap or build something decent....i hope that 2400 wasn't a quote for a stock rebuild</TD></TR></TABLE>
Could be ever more... a rebuild like that would pretty much make the motor new with 0 miles not "low millage" like jdm motors and the price depends on how much work the OP will do himself, if her just drives his car into a shop its probably going to be more than 2400
Old Oct 30, 2007 | 04:50 PM
r3v da t3g's Avatar
Default Re: Bad Piston Rings (St Jimmy)
the car is a 91 integ with a b18c. . . . and 2400. . . thats 400 more than what i bought the car for.
92civichbor
10
Aug 5, 2008 11:09 AM
Modern91Hatch
Jul 13, 2006 02:57 PM
aser1z
Sep 12, 2005 08:57 PM
hondaguyef
Jul 8, 2004 02:51 AM
