EVAC / IVAC troubles obd0 dpfi to obd1.
I finished my dpfi to obd1 conversion a while back. Once in a while I get a code 14. Usually I disconnect my obd0-obd1 conversion harness and it goes away. So I guess I'm looking for some kind of short in the EVAC (obd0) / IACV (obd1). The stock dx harness should be A11 (blu/ylw), but if I remember there is two other wires that goto the EVAC / IACV. Any one know what there numbers are to the stock dx harness?
on obd0 and obd1 theres just two wires, blue black is one, yel black is the other and it won't necessarily be found at an ecu pin, yel/blk is a power wire that comes from your main relay. Check if for power with a multi meter, if that wire has power and the blue black is at the right pin location then your set
i had this same exact problem. i rewired it and fixed the problem...
i tied the yel/blk in with the yel/blk on the fuel injectors. i tied the other wire straight into my conversion harness to the right pin...
well i tried burn a new eprom for my ecu that would disable the IACV. No go, can't get a good working burn. I'm going to be trouble shooting the issue when i get home. Woopty do! thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">place called streetlightz.com paid under 50 bucks shipped to the door</TD></TR></TABLE>
maybe thats your problem?
haha.. it worked fine before and just started to act up. i was just thinking of making my own. or just swapping gray plugs to th existing harness. but then the issue would be in the conversion harness.
dr_latino999
236
Mar 28, 2020 12:34 AM
SpokaneSpeed
61
Jun 17, 2014 09:57 AM
954dooreg
27
Apr 16, 2008 09:02 AM
