something is rattling in the cat converter
Do you have a check engine light? I had the same problem... my cat was gone, and had check engine light and had to get a new one. The catalyst inside was falling apart. But it should not happen if its brand new unless its a cheap cat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bballchris24 »</TD></TR><TR><TD CLASS="quote">Do you have a check engine light? I had the same problem... my cat was gone, and had check engine light and had to get a new one. The catalyst inside was falling apart. But it should not happen if its brand new unless its a cheap cat.</TD></TR></TABLE>
i dont have a CEL cause it does not have a o2 sensor bunk ..the cat converter is about $120.
Well I hate to say it but i think your catalytic converter might be gone. Rattling is not normal and rattling usually means the catalyst inside has broken apart. By being a brand new catalytic converter, it just has to be bad luck.
But just to be sure, anybody else have a say?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bballchris24 »</TD></TR><TR><TD CLASS="quote">Well I hate to say it but i think your catalytic converter might be gone. Rattling is not normal and rattling usually means the catalyst inside has broken apart. By being a brand new catalytic converter, it just has to be bad luck.
But just to be sure, anybody else have a say?</TD></TR></TABLE>
thanks man..
thanks man..
If you got warranty on that cat, i say try to get a new one or let who ever changed it for you inspect it agian.
Usally rattling would be your bushings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinoyDelSol »</TD></TR><TR><TD CLASS="quote">If you got warranty on that cat, i say try to get a new one or let who ever changed it for you inspect it agian.
Usally rattling would be your bushings.</TD></TR></TABLE>
What are you talking about? What bushings? Sounds like you need a new cat, If smog is no time soon I would just take it off shake the stuff out and reinstall it. Then get a replacement when smog comes.-ejoner.
Usally rattling would be your bushings.</TD></TR></TABLE> What are you talking about? What bushings? Sounds like you need a new cat, If smog is no time soon I would just take it off shake the stuff out and reinstall it. Then get a replacement when smog comes.-ejoner.
Like i said, if he still has warranty on the cat from where ever he bought it from. He should be able to get a brand new cat. Or Where ever he got it installed from, he should let them look at and see whats the rattling coming from. Most of the time the bushings, the black rubber pieces that hold your exhaust hangers would let the whole exhaust system rub against the chassis and cause a vibrating noise which gives him the rattling noise. Anything else you dont understand from me?
if your running stock piping are you sure its your cat? because i have the same problem w/ my stock vx piping accept its my resonator it rattles really loudly at like 2k rpm and its got some broken apart crap in there..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by themikewoo »</TD></TR><TR><TD CLASS="quote">Is it a brand new OEM cat?</TD></TR></TABLE>
no it is not oem..it is brand new from muffler shop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doubleshotz »</TD></TR><TR><TD CLASS="quote">Is your header collector ID and catalytic conveter inlet ID same?</TD></TR></TABLE>
i will have to ckeck on this one..i dont think they are the same...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks »</TD></TR><TR><TD CLASS="quote">anything new with this thread? i have the same problem with my cat and it's only three months old</TD></TR></TABLE>
i am going to take my down pipe off this weekend and see if the collect metal o ring is worn or torn or something cause i was suppose to use a metal gasket instead of the o ring type of gasket donut .if it is still good. then i am bring it back to the muffler shop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doubleshotz »</TD></TR><TR><TD CLASS="quote">Most likely it's the heatshield on your cat.
Pull it out and see if it stops.</TD></TR></TABLE>
It is very rare for cats to go bad that fast. It usually takes a few years to go bad. My moneys on your heat shield as well.
