skunk2 throttle body
Old Oct 30, 2007 | 12:09 PM
ekslammed's Avatar
Default skunk2 throttle body
Has anybody noticed any difference with one of these installed??
Old Oct 30, 2007 | 12:20 PM
A Blue Lude's Avatar
Default Re: skunk2 throttle body (ekslammed)
Yeah, big difference. Car is very hard to drive.
Old Oct 30, 2007 | 06:36 PM
lurken's Avatar
Default Re: skunk2 throttle body (A Blue Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A Blue Lude &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, big difference. Car is very hard to drive.</TD></TR></TABLE>
how is the car hard to drive??? i just got the pro series intake mani and 70mm throttle body but have not intalled yet. car is boosted and hoping for a pretty good gain from them.
Old Oct 30, 2007 | 06:37 PM
1994PreludeSi's Avatar
Default Re: skunk2 throttle body (lurken)
Sarcasm...
Old Oct 30, 2007 | 07:35 PM
lurken's Avatar
Default Re: skunk2 throttle body (1994PreludeSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1994PreludeSi &raquo;</TD></TR><TR><TD CLASS="quote">Sarcasm...</TD></TR></TABLE>
got'cha kinda figured but who knows
Old Oct 30, 2007 | 07:40 PM
h23prelude's Avatar
how so, in a bad way?
Old Oct 30, 2007 | 07:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lurken &raquo;</TD></TR><TR><TD CLASS="quote">
how is the car hard to drive???</TD></TR></TABLE>
TB doesn't like opening. The force required to open then opens it a lot. In short, the TB is sticky and the the car is very jerky to drive because of it.
Old Oct 30, 2007 | 08:34 PM
lurken's Avatar
in the instructions i got with mine show how to help fix that with a adjustment screw tho
Old Nov 1, 2007 | 09:27 AM
in the instructions i got with mine show how to help fix that with a adjustment screw tho</TD></TR></TABLE>
Yes, the adjustment screw is a good place to start to ensure good TB operation.
Old Nov 1, 2007 | 03:06 PM
QUIETP_11's Avatar
Adjusting that return limiting screw will likely require adjustment of the TPS as well.
That's the last thing I can think of....if that doesn't work, I'm probably going to get rid of Skunk2 TB.
Old Nov 1, 2007 | 04:09 PM
Default Re: skunk2 throttle body (QUIETP_11)
If you move it a lot, maybe. But you can get away with a surprising amount.
Old Nov 1, 2007 | 06:37 PM
Rosko's Avatar
the problem with mine was it had too much play in it, causing the blade to rub on the side on the throttle bore and get stuck. thats what keeps it from closing and or makes it stick.
I ended up taking it apart and reworking a few things and now it works fine.
Old Nov 1, 2007 | 06:40 PM
98vtec's Avatar
moderator emeritus
Default Re: skunk2 throttle body (Rosko)
i wish i could have had it for the manifold test
Old Nov 1, 2007 | 06:43 PM
Rosko's Avatar
Default Re: skunk2 throttle body (98vtec)
yeah it was a pita out of the box. I can lend it to you again this winter if you want to try it again, the cars prolly gonna be in storage till its warm again.
Old Nov 1, 2007 | 07:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">the problem with mine was it had too much play in it, causing the blade to rub on the side on the throttle bore and get stuck. thats what keeps it from closing and or makes it stick.
I ended up taking it apart and reworking a few things and now it works fine.</TD></TR></TABLE>
Any more detail? That's what mine does too afaik. It moves laterally, within the bore. It's a really small amount, but it does do it.
Old Nov 1, 2007 | 07:22 PM
Rosko's Avatar
Any more detail? That's what mine does too afaik. It moves laterally, within the bore. It's a really small amount, but it does do it.</TD></TR></TABLE>
It involved remaking the spacer underneath the spring so that everything would tighten up against the bearing with zero play.
Old Nov 1, 2007 | 07:25 PM
Damn, something that requires talent
That's good to know. I didn't know if I could fix it doing that.
It's made me really want to go back to OEM, but between the OEM TB being bonded to the manifold and talked about FITV leaks on the Euro-R I've resisted the temptation...so far.
edit: I should say though, the IM/TB swap could have gone off much worse. Just the S2 throttle body and a slight *cough* slight over torquing of the FPR bolts. Stupid FPR
The Euro-R is the cleanest part of the engine!
Modified by A Blue Lude at 9:00 PM 11/1/2007
Old Nov 1, 2007 | 08:01 PM
Prudz_lude's Avatar
so let me get this straight, sk2 TB's are garbage out of the box? you have to modify them to work properly?
Old Nov 2, 2007 | 09:10 AM
UK_Luder's Avatar
Default Re: skunk2 throttle body (Prudz_lude)
Had no problem with mine. I believe the recent 'Pro series' TB was meant to correct some minor design issues.
Old Nov 2, 2007 | 09:18 AM
Prudz_lude's Avatar
Default Re: skunk2 throttle body (UK_Luder)
hmmmm so it would be safe to buy a new one?
Old Nov 2, 2007 | 09:22 AM
Hawkze_2.3's Avatar
FWIW, I have had ZERO problems with my Edelbrock TB Worked great since day one...
Old Nov 2, 2007 | 09:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude &raquo;</TD></TR><TR><TD CLASS="quote">hmmmm so it would be safe to buy a new one?</TD></TR></TABLE>
Mine was bought late summer. And it really has been crap so far. Hopefully I can pull off Rosko's solution.
Old Nov 2, 2007 | 12:42 PM
ekslammed's Avatar
i just got one... o well we'll see what happpens
Old Nov 2, 2007 | 02:22 PM
It's pretty easy to see how sticky it is in your hands. And you should adjust the throttle stop as much as you can before you install it.
Old Nov 2, 2007 | 05:07 PM
Halo's Avatar
are these issues specific to skunk? Anyone tried the bdl tb? Luders buy the ITR Tb right?
Modified by Halo at 7:15 PM 11/2/2007
