94+ brakes and rotors on 92 integra?
Old Oct 30, 2007 | 10:33 AM
7808's Avatar
Default 94+ brakes and rotors on 92 integra?
i can get new 94+ rear rotors and pads cheaper, with these go right on my 92 integra?
Old Oct 30, 2007 | 10:45 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: 94+ brakes and rotors on 92 integra? (7808)
i'll let you find the answer yourself
http://www.autozone.com
search them both...if same part numbers then yes, if not then no
it would be easier for me just to tell you but go prove it to yourself
Old Oct 30, 2007 | 10:48 AM
7808's Avatar
Default Re: 94+ brakes and rotors on 92 integra? (GRAF-FITI)
ya cause autozone's search knows all possible interchangeablitys.
ill give you a little lesson right now, went in there for a new radiator for my prelude the other day, $170. said give me one for an accord, $80. everything fits the same.
i want to know if they will work, not if they haev the same autozone part number
Old Oct 30, 2007 | 11:31 AM
GRAF-FITI's Avatar
* B A N N E D *
thanks for your lesson, i'll remember that when i go for my ASE re-certification
here's a little lesson for you: nobody held your hand when you bought an accord radiator for your prelude, why should anyone now?
brake pads are what, 20 bucks for a set of 4? rotors are around 25 bucks, a piece? quit being cheap and go with the vehicle specific application...
Old Oct 30, 2007 | 11:51 AM
7808's Avatar
my car is on its last leg i wouldnt even replace them if they didnt make the loudest noise thats why im beaing cheap, hell i might just take the pads out and block the line
and with the radiator i knew it would i dont wana take all my rusty *** caliper n brakets off to find out the pad dont sit right or somthings off 2mm thats why im asking if anyknow knows forsure not autozone part numbers, but i checked and they are the same so thanks
yoru ase certification dont mean nothin to me, half the time i go in some shop some ase badged up retard looks at my car and nothing makes sense to them anyways. what you have a turbo in there and that motor is from another kind of car?? that wont work!?
Old Oct 30, 2007 | 12:13 PM
GRAF-FITI's Avatar
* B A N N E D *
agreed...but there are numerous types of ASE certifications..mine isn't for parts pro
and agreed again, there are ALOT of idiots at those parts stores...
Old Oct 30, 2007 | 05:13 PM
2ndgent3g's Avatar
why dont you just do the legend brake upgrade if anything...
Old Oct 31, 2007 | 07:58 AM
asr10 user's Avatar
Stop being cheap.
Old Nov 1, 2007 | 03:42 PM
7808's Avatar
Default Re: (2ndgent3g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndgent3g &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just do the legend brake upgrade if anything...</TD></TR></TABLE>why dont you learn to read
Old Nov 4, 2007 | 09:17 AM
darrinbrewer's Avatar
Default Re: (7808)
part numbers are different from acura. 95 gsr uses 7CLP-13S rear caliper, look on yours to see if the same caliper.
check nopi for brembo part numbers, i know when you look up front for a teg, 96 ex civic, 95 ex/abs civic....there all the same 10.3" rotor. just check for the rear
Old Nov 4, 2007 | 10:30 AM
redDAinteg's Avatar
Default Re: (darrinbrewer)
Thats why you don't see too many good looking DA's, because they have CHEAP *** owners.
KtHaNxBai
Mar 26, 2012 04:04 PM
LS AzZkIkr
Feb 1, 2011 08:10 AM
cyclonedr
Dec 10, 2009 01:13 PM
curiousgpnoy
Jan 11, 2004 04:46 PM
NWAS
Feb 20, 2003 07:02 AM
