Cluster Problem
Old Oct 30, 2007 | 06:24 AM
Ryan.'s Avatar
Default Cluster Problem
I have a 1999 Civic Si and just recently the cluster has been acting up.
Example:
I will be driving and everything appears to be working just fine and then out of nowhere the cluster will stop working. If this happens at night the lights on the cluster will remain on but the gauges wont work. Then randomly they will work again. It has to be a loose connection somewhere but I have already taken the cluster out and looked at that and also checked all my grounds.
Any ideas?
Old Oct 30, 2007 | 06:34 AM
97Ej6mike's Avatar
Only way to tell if its just that cluster and not the wiring is to try another cluster in there.
This type of electrical inconsistency doenst happen with your dash lighting, radio or other lighting, like in cases of a faulty alternator?
Old Oct 30, 2007 | 06:35 AM
Ryan.'s Avatar
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Only way to tell if its just that cluster and not the wiring is to try another cluster in there.
This type of electrical inconsistency doenst happen with your dash lighting, radio or other lighting, like in cases of a faulty alternator?</TD></TR></TABLE>
Nope. Just the gauges in the cluster. I have been told to check the wiring around the ecu to make sure everything is secure.
Old Oct 30, 2007 | 06:44 AM
97Ej6mike's Avatar
That may be the case. Any recent electrical work or wiring, or just about any event that has happened recently before everything started acting up? Take note that water-damage can cause electrical things to act funny, example being a VSS sensor. Ive seen a case or two where water/coolant settled in the plug of the sensor (sits upright like a bowl) causing the speedometer needle to sometimes jump randomly all over the guage, bounce from place to place, read completely wrong, even just stop working.
Old Oct 30, 2007 | 06:46 AM
Ryan.'s Avatar
I will check that out it has rained a good amount lately.
eg6REDmilano20
Jan 11, 2010 01:35 PM
kcrxxx
Jul 27, 2007 01:42 PM
ronintegra
Jan 3, 2006 12:10 PM
