High Compression Pistons for D16Z6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18frank »</TD></TR><TR><TD CLASS="quote">I would like to know wat are the best high compression pistons to buy...and if i can get anything close to CTR pistons</TD></TR></TABLE>
You can actually do a hybrid build using 2001-2005 civic GX (natural gas) pistons and internals on a D block. They did a writeup in a honda-tuning issue on this called super D, where the guy put down around 170hp with 136trq , at a 13:2:1 CR. Try PM'ing the user and Mod, Bense. I believe he knows a thing or two about this type of build.
You have an abundance of piston choices.
I'm running P29 (88-89 Integra D16A1) pistons in my 1988 D16A6 engine and I've got a touch over 11:1CR, but they increase CR in a VTEC engine differently.
Here's a fun CR calculator to play with:
http://www.knology.net/~jediklc/D.htm
Punch in the various engine set-ups and check the estimated comp ratios.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">
You can actually do a hybrid build using 2001-2005 civic GX (natural gas) pistons and internals on a D block. They did a writeup in a honda-tuning issue on this called super D, where the guy put down around 170hp with 136trq , at a 13:2:1 CR. Try PM'ing the user and Mod, Bense. I believe he knows a thing or two about this type of build. </TD></TR></TABLE>
I eard about this I have tryed finding this write up on the web but have had no luck any help on were I can find it?
