My engine build/Need a good tuner in southern PA or Northern MD
I finally got all the parts I needed to get my motor done this past summer and built/swapped it in august, it only has 293 miles on it and is ready for my turbo setup to go on... I need to find a good tuner in the south central PA area or Northern Maryland area before the turbo goes on, if anyone has any in mind or know of any reputable people let me know!! thanks
Motor Specs:
Probe forged Pistons(81.5mm, 8.5:1 compression)
Probe H-beam rods
Block Decked .010"
Block Bored .20 over
Block guard
ARP head studs
ARP rod bolts
Cometic head gasket
Head built by JG:
Port & Polish
Over sized intake valves
JG Springs/retainers
JG turbo cams
JG adjustable cam gears
Polished combustion chamber
After all the machine work and what not was done the compression comes out to 9:1
The turbo's going to go on probably in the spring time when school's finished up and the car's broken in(I barely drive it at school...)
The build/swap took me two weeks
but I guess that's not too bad for working two jobs seven days a week during the summer...
and don't worry, the valve cover isn't staying yellow, it's just all I had at the moment
waiting patiently, 2000 bumpers in the background
the result of getting caught in a flash flood earlier that summer, so glad I couldn't afford a good cold air intake at the time
so fresh
That's right, ratchet straps
notice the shift linkage is still attached... stupid bitch pin...
Since then I've done my front bumper conversion and waiting on the rear for when I can afford the paint, and traded my old motor for ls meshies
Once again if anyone knows of any good tuners in my area let me know! thanks
Modified by berb_15 at 12:40 AM 10/30/2007
Modified by berb_15 at 12:47 AM 10/30/2007
Motor Specs:
Probe H-beam rods
Block Decked .010"
Block guard
ARP head studs
ARP rod bolts
Cometic head gasket
Head built by JG:
Port & Polish
JG turbo cams
but I guess that's not too bad for working two jobs seven days a week during the summer... and don't worry, the valve cover isn't staying yellow, it's just all I had at the moment
so fresh
thanks, it'll defiantly fit the b18b but check out edelbrocks website im pretty sure they have dimensions on there. it was a tighter squeeze in the integra and im assuming it may be even tighter in a civic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k624ash »</TD></TR><TR><TD CLASS="quote">http://www.evans-tuning.com/index.html</TD></TR></TABLE>
or r/t tuning in lansdale
The best around
The best around
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weavertime1 »</TD></TR><TR><TD CLASS="quote">J-K-tuning.com</TD></TR></TABLE>
doesnt answer his phone or return calls
http://www.evans-tuning.com looks good but is a long haul for me ill definitely be keeping them in mind
Keep them coming! thanks
Modified by berb_15 at 8:15 AM 10/30/2007
From: Why To Steal My Car, NC, United States Of America
looks great but have one question why so many straps tied to the engine i only used 1 chain check how i did it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCgarage919 »</TD></TR><TR><TD CLASS="quote">looks great but have one question why so many straps tied to the engine i only used 1 chain check how i did it</TD></TR></TABLE>
I don't know guess it made me feel more secure haha, what did you use as lift points??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 »</TD></TR><TR><TD CLASS="quote">how about booze brothers? down on 11?
never heard of them where on 11 is it and have you been there?? thanks
Modified by berb_15 at 11:32 AM 10/30/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by berb_15 »</TD></TR><TR><TD CLASS="quote">
Modified by berb_15 at 8:15 AM 10/30/2007</TD></TR></TABLE>
how far is it for you? i think he is like 2 hours from me, but thats where im gonna go
JE Import Performance i'v heard good things about. They are out of Baltimore and belive they specialize in Hondas. http://www.jeimportperformance.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror »</TD></TR><TR><TD CLASS="quote">
The best around </TD></TR></TABLE>
Evans tuning may be the best around, but...you can't just call up and get your car in tomorrow...I have heard wait time as long as months...Good luck tho!!!
Thanks for all the suggestions guys they will definitely help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 »</TD></TR><TR><TD CLASS="quote">looks like a solid build! whats the hp goal and psi you are tryin to run? </TD></TR></TABLE>
Thanks I've been planning it for a while but as far as hp goes I was hoping anywhere from 300-350? but the hp numbers and psi are still kind of up in the air until I talk to a tuner... the internals are ready for anything but Im still running on stock cylinder walls so Im not 100% sure yet...
how far is it for you? i think he is like 2 hours from me, but thats where im gonna go</TD></TR></TABLE>
well if it's in the easton by philly its about 2 1/2 hours if its the one closer to pitt its about 3 1/2... 2 1/2 isnt too bad though
booze brothers racing, its in marion, leave chambersburg, go south on 11, its on the left hand side, beside cebco gas station. charlie booze owns it, hes the number one drag mustang driver on the east coast. they built some of the worlds fastest mustangs, and they are good with sport compact too. http://www.yellowbook.com/sear...&y=11
Your car is slow chris, and will never be as awesome as mine...bwahahaha
ps; i know you loved my dancing moves at psu with the big ladies...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 »</TD></TR><TR><TD CLASS="quote">booze brothers racing, its in marion, leave chambersburg, go south on 11, its on the left hand side, beside cebco gas station. charlie booze owns it, hes the number one drag mustang driver on the east coast. they built some of the worlds fastest mustangs, and they are good with sport compact too. http://www.yellowbook.com/sear...&y=11</TD></TR></TABLE>
Thanks Ill have to check them out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike5809 »</TD></TR><TR><TD CLASS="quote">Your car is slow chris, and will never be as awesome as mine...bwahahaha
ps; i know you loved my dancing moves at psu with the big ladies...</TD></TR></TABLE>
how did I know you were going to poke your nose in my thread haha
he is the best honda tuner around and its safe give him a call or email u will never regret trust me and if u go for a retune its cheaper
