ECU will not turn on
Old Oct 29, 2007 | 11:10 PM
dump3deg6's Avatar
Default ECU will not turn on
Okay.. I have a 91 Civic Wago, and everything was working fine.. I cranked it up, moved it to my garage, turned the key off, and not more than 5 mintues went by and i tried to crank it again. The check engine light doesnt turn on, and i pulled the carpet back to see if the ecu blinked, and it didnt do anything. First thing that came to mind was the main relay.. Changed it, nothing happened.. The car turns over, and all dash lights work except the check engine light. I hear no fuel pump either
I check ALL fuses, all fuses fine.. Im confused, and need help. This is my only daily and i need this to run quite badly. Only other thing i can think of is the ecu, but im not sure if its that..
Anyone have a simular prob? Or someone know a way to jump the ecu to make it manually turn on??!?!?
Old Oct 29, 2007 | 11:44 PM
EF_LSVtec's Avatar
Default Re: ECU will not turn on (dump3deg6)
that happened to me but alternator or some not related fuse popped...check all underdash fuses again.
Old Oct 30, 2007 | 12:43 AM
Cheeech's Avatar
Default Re: ECU will not turn on (EF_LSVtec)
same thing happen to me and it was my #14 fuse, also check your thermastat ground
Old Oct 30, 2007 | 03:07 AM
SETI20's Avatar
Yes, don't just check the dash fuses. CHeck the under hood fuses.
Could be your main fuse.
K i l l a B e e.
11
Sep 1, 2008 01:08 AM
FukinCrx
Jul 20, 2008 01:08 PM
Cashkidd720
Mar 18, 2008 07:12 AM
