Quarter Panel Question
So im going to be starting the body work on my rear quarter panel soon and i was wondering after i sand down and apply filler and hardener what kind of primer should i use?
well buddy if you dont know that hardener goes into the filler then I dont think you will be ready for primer. read up. theres a big red search button the right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedjdmdc2 »</TD></TR><TR><TD CLASS="quote">So im going to be starting the body work on my rear quarter panel soon and i was wondering after i sand down and apply filler and hardener what kind of primer should i use?
First off, you need to sand the body filler after you apply it to the repair area. Then when you are all finished sanding, and pleased with your repairs, you want to use a primer filler. The primer filler will fill in your sand scratches (provided you used the correct grit of sand paper).
Modified by WihaSi at 8:59 AM 10/30/2007
</TD></TR></TABLE>First off, you need to sand the body filler after you apply it to the repair area. Then when you are all finished sanding, and pleased with your repairs, you want to use a primer filler. The primer filler will fill in your sand scratches (provided you used the correct grit of sand paper).
-[95cxhatch]-
14
Feb 14, 2006 08:31 AM
