suspension???
i was thinking bout putting an ASR brace on my sedan along with sum blox LCAs and front and rear camber kit... is the brace a straight bolt up or is drilling needed?
Straight bolt up. But this is the wrong forum.
Just so you know before buying the brace it won't make a noticeable difference unless you put a sway bar with it. The 22mm ITR one is the easiest to get. Be sure to get a full alignment at a reputable shop after installing the camber kit and control arms.
Goodluck. I have a similar set up.
professorman
Dec 31, 2009 12:42 AM
The Si
Suspension & Brakes
Mar 12, 2007 11:29 PM
