P30 bearings for an LS Vtec?
Old Oct 29, 2007 | 09:16 PM
DC_Legacy's Avatar
Default P30 bearings for an LS Vtec?
Sorry to bother with this post, but I searched and couldn't find much information on this topic.
Im currently building a mild LS Vtec and I've read that P30/B16 bearings can be used as an alternative to standard LS bearings, or aftermarket ACL's, and others.
By comparison standard LS bearings have a small hole located off center on the bearings to match an oil galley on the LS rods, the P30/B16 bearings do not have this hole.
Suppose I were to use P30 bearings instead of LS bearings. Would I encounter any kind of problems or possible engine failure as a result of using the P30/B16 bearings which don't feature this hole?
Old Oct 31, 2007 | 04:25 AM
mmuller's Avatar
Mad Scientist
Default Re: P30 bearings for an LS Vtec? (DC_Legacy)
if you do want to use p30 bearings have a machine shop drill the bearings for the hole.
that hole does the job that squirters do on vtec motors. oil goes through bearing , through rod and into bottom of piston
Old Oct 31, 2007 | 05:04 AM
DC_Legacy's Avatar
Default Re: P30 bearings for an LS Vtec? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">if you do want to use p30 bearings have a machine shop drill the bearings for the hole.
that hole does the job that squirters do on vtec motors. oil goes through bearing , through rod and into bottom of piston</TD></TR></TABLE>
Yeah thats what a few people have told me on another thread. Thanks!
kyden
May 7, 2009 10:30 AM
vtec4max
Nov 28, 2007 01:56 PM
DC_Legacy
23
Nov 2, 2007 04:14 AM
pane93civhb
Jan 23, 2005 12:21 PM
