'95 EX Auto Accord w/ OBD1 H22 swap....what ECU?
Old Oct 29, 2007 | 08:29 PM
C_Rock77's Avatar
Default '95 EX Auto Accord w/ OBD1 H22 swap....what ECU?
Looking to put an OBD1 H22 swap in my '95 Accord. What ECU should I use? I'm sure I could get one chipped fairly easily. Should I just have my stock ECU chipped? Is there any way to make an OBD1 P13 an AUTO ECU?
Old Oct 29, 2007 | 11:19 PM
Twixle's Avatar
ate my pixel
Default Re: '95 EX Auto Accord w/ OBD1 H22 swap....what ECU? (C_Rock77)
I believe you can repin the F22B1 ecu to run an H22 pretty easily. The 95 accord was OBD1, so you shouldn't have any compatibility problems.
Old Oct 30, 2007 | 07:44 AM
Bird333's Avatar
Default Re: '95 EX Auto Accord w/ OBD1 H22 swap....what ECU? (Twixle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twixle &raquo;</TD></TR><TR><TD CLASS="quote">I believe you can repin the F22B1 ecu to run an H22 pretty easily. The 95 accord was OBD1, so you shouldn't have any compatibility problems. </TD></TR></TABLE>
Uh, you MAY be able to re-pin the F22b1 ecu but a H22 engine has different fuel and ignition maps not to mention that an H22 has IAB's to be controlled. In short, use the ecu for that engine or chip an ecu to use compatible fuel and ignition maps.
Old Oct 30, 2007 | 08:03 AM
hurleyint's Avatar
Default Re: '95 EX Auto Accord w/ OBD1 H22 swap....what ECU? (Bird333)
Automatic tranny? You need an automatic p13, which is the stock ecu for the h22.
Old Oct 30, 2007 | 01:23 PM
C_Rock77's Avatar
Default Re: '95 EX Auto Accord w/ OBD1 H22 swap....what ECU? (hurleyint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hurleyint &raquo;</TD></TR><TR><TD CLASS="quote">Automatic tranny? You need an automatic p13, which is the stock ecu for the h22.</TD></TR></TABLE>
I'd just never heard of an OBD1 Auto H22 ECU.
Was considering getting one chipped.
Old Oct 31, 2007 | 06:03 PM
hurleyint's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_Rock77 &raquo;</TD></TR><TR><TD CLASS="quote">
Was considering getting one chipped. </TD></TR></TABLE>
Sometimes you can find them on ebay, or you could try to get a jdm engine importer to find you one. You will also need the JDM TCU (P19) to shift to redline.
Old Nov 15, 2007 | 06:40 AM
C_Rock77's Avatar
Sometimes you can find them on ebay, or you could try to get a jdm engine importer to find you one. You will also need the JDM TCU (P19) to shift to redline.</TD></TR></TABLE>
Not really that worried about that....can just shift manually w/ the automatic, right?
Would I be able to chip the stock Accord ECU? I have a friend that chips ECUs.
Old Nov 15, 2007 | 09:08 AM
hurleyint's Avatar
Would I be able to chip the stock Accord ECU? I have a friend that chips ECUs. </TD></TR></TABLE>
You WILL NOT be able to shift (even manually) past the stock redline without the h22a TCU. The fuel maps are also different since the h22 revs higher and has VTEC. Even if you chip an accord ECU for the correct fuel maps, the ecu doesn't have the capability to control all of the functions of the H22. Find a P13 AUTO and a P19 TCU. Don't half-*** it man.
Old Nov 17, 2007 | 08:24 AM
C_Rock77's Avatar
Will the P19 be PnP on this tranny?
Old Nov 17, 2007 | 09:43 AM
hurleyint's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_Rock77 &raquo;</TD></TR><TR><TD CLASS="quote">Will the P19 be PnP on this tranny? </TD></TR></TABLE>
Here is a link about installing the TCU. http://accordinglydone.com/for....html
Old Mar 24, 2008 | 07:20 PM
nspec_Cd5's Avatar
did u use teh stock f22 tranny?
and did u originally had a vtec f22 in ur car?
also what all did u have to do make the f22 vtec wire harness work?
GraphiteMW
Jan 13, 2009 02:58 PM
mmk21
10
Feb 15, 2008 06:14 AM
h222accord92
Aug 8, 2007 12:10 PM
Godspeed94
Apr 7, 2005 12:54 PM
