Shell gasoline wreaking havoc on FI Hondas?
Old Jun 22, 2002 | 12:42 AM
PyroVTEC's Avatar
New User
Default Shell gasoline wreaking havoc on FI Hondas?
Okay, a little off topic perhaps, but I have no idea what's up with Shell gasoline in Cali recently... every time I fill up with Shell fuel, I get slight detonation under WOT near 6psi on my D16Y8 (stock internals). When using Unocal 76, Chevron... it's all OK.
What's going on? Anyone else in Cali experiencing this problem? One would figure that Shell is a first rate gasoline company!
Old Jun 22, 2002 | 01:09 AM
Brandon's Avatar
Life is Suffering
Default Re: Shell gasoline wreaking havoc on FI Hondas? (PyroVTEC)
Well, I know I dont live in Ca, but the regulations on fuels there are so tough that it is hard for most companies to get the octane numbers high enough. They have used alcohol in the fuel which is more environmentally friendly, but it is bad for knock resistance. Just use the fuel from places which tend to give you the best results.
Old Jun 22, 2002 | 01:29 AM
R-1303's Avatar
I heard shell has some water based substance **** in their gasoline..lets say that years down the line you had to replace your stock fuel cell there will be bits of water if you use shell...i always run 76 or cheveron..even though i could walk to shell by my house..i live in cali to and the summer isn't doin to good for us but i notice a smoother running car with cheveron....ITR stock internals boosted 7 lbs
[Modified by R-1303, 10:30 AM 6/22/2002]
Old Jun 22, 2002 | 08:17 AM
reXem's Avatar
Default Re: Shell gasoline wreaking havoc on FI Hondas? (R-1303)
Here in Canada...nothing beats Chevrons 94 octance.....a friend of mine has a 81 GMC Sierra Truck done up completely and he has to drive like 80kms to get to achevron....well he was out of gas and needed to go fill up so he put some mohawk gas (94 octane) in and went to go to the chevron...he truck would stutter and sputter going up hills...he had little bit of chevron in his other tank so he flipped it over and the truck ran great.... Chevron Anything else .....No Chevron in Calgary
Old Jun 22, 2002 | 09:33 AM
Madness's Avatar
Default Re: Shell gasoline wreaking havoc on FI Hondas? (accordvtec)
alcohol in the fuel is bad for knock resistance
wtf? most octane boosters are alky-based
Old Jun 22, 2002 | 09:53 AM
Brandon's Avatar
Life is Suffering
Default Re: Shell gasoline wreaking havoc on FI Hondas? (dante_420)
Fuel companies have used ethanol for a long time as a cheap way of getting it past state regs. I try to only go to Gate gas stations, but I have a good deal of trouble finding them outside of Greensboro. They tend to have the least cases of bad fuel, and my car runs great on it.
Old Jun 22, 2002 | 11:38 AM
SlowB16's Avatar
just go to Chevron!!!!
Old Jun 22, 2002 | 12:17 PM
xci_ed6's Avatar
Default Re: Shell gasoline wreaking havoc on FI Hondas? (SlowB16)
Ethanol=good
Ethanol=corn alchohol
Buy ethanol fuels!!!
-Dustin
Old Jun 22, 2002 | 12:36 PM
SIK IN DA HED's Avatar
New User
Default Re: Shell gasoline wreaking havoc on FI Hondas? (Autocratic_1st_Gen)
shell sucks anyways.
Old Jun 27, 2002 | 12:12 PM
siboosted's Avatar
Default Re: Shell gasoline wreaking havoc on FI Hondas? (dlplayboy)
I use 93 octane at the Amoco here and I have never had a problem.
Old Jun 27, 2002 | 02:35 PM
Trac226's Avatar
Default Re: Shell gasoline wreaking havoc on FI Hondas? (siboosted)
Ethanol is the way to go here in cali, that MTBE crap most gas stations use is crap for the environment (lol, like an open downpipe isn't). I have a Shell station right near my house but i drive about two miles down the road for 76 because my car feels like it bogs with Shell. 91 octane
Old Jun 27, 2002 | 02:59 PM
ion_four's Avatar
Default Re: Shell gasoline wreaking havoc on FI Hondas? (Trac226)
I always use Chevron, if I can. Even ignoring it's resistance to knock, it's a better fuel because it has the techron fuel cleaner in it which is the only fuel cleaner on the market, that I know of, that doesn't deteriorate plastic and rubber components in the system...I also know a guy that works at a Chevron here in Portland (full-service only) and they really keep their lines and pumps clean...just to share.
Old Jun 27, 2002 | 04:14 PM
BlowOff's Avatar
New User
Default Re: Shell gasoline wreaking havoc on FI Hondas? (ion_four)
I hear shell and BP gas sucks. I refuse to use their gas.
Chevron or Sunoco are good though. In my area I use Sunoco 94 octane
Old Jun 27, 2002 | 04:35 PM
DeL SLo's Avatar
Default Re: Shell gasoline wreaking havoc on FI Hondas? (BlowOff)
i guess im the odd one of the group, i hate chevron. i notice my car doesnt run as well and i get worse mpg vs tex/shell.
Old Jun 27, 2002 | 04:44 PM
bigTom's Avatar
Default Re: Shell gasoline wreaking havoc on FI Hondas? (DeL SLo)
i guess im going out on a limb here but i use mobil and sunoco... no problems here (at least when i had a car)
Old Jun 27, 2002 | 05:20 PM
ekb18c's Avatar
Default Re: Shell gasoline wreaking havoc on FI Hondas? (ek9t)
Sunoco 94 ! Thats the only gas that goes into my car. Well, with the exception of Cam2 (100 octane) sometimes.
Old Jun 27, 2002 | 05:57 PM
tmg's Avatar
tmg
Default Re: Shell gasoline wreaking havoc on FI Hondas? (ekb18c)
boy does it pay to be in a non-emission state. i use 93 shell and chevron. they're both my pics here. unocal 76 was the shiznit when i used to live home in cali.
Old Jun 27, 2002 | 06:12 PM
twkdCD595's Avatar
Default Re: Shell gasoline wreaking havoc on FI Hondas? (themi6group)
Shell is not so bad out here really... not the best but alot of very nice shell stations around here. They do have 10%ethanol in their gas they say here also (seen it on the sticker on pump).
Could be the owner of that shell franchise getting bad or sub-standard gas though.
Couldn't you call those test people (state ones or whatever) and have them check... they do that **** on a tip from people calling in. Anyone know the name for it though... I forgot?
Anyways I like the QT or certain Mobil stations, and a far away station by track has 100 octane cam2... 76 station I think... will hope to make use of it sometime.
[Modified by twkdCD595, 7:14 PM 6/27/2002]
Old Jun 27, 2002 | 07:19 PM
G_Man604's Avatar
Default Re: Shell gasoline wreaking havoc on FI Hondas? (twkdCD595)
while you guys are happy with your 93-94 octane, i moved back to philippine with my boosted b18c and PETRON has 97+ octane unleaded gas *hopefully it is 97 octane* haha
Old Jun 27, 2002 | 07:20 PM
csufweed's Avatar
i got bad gas from chevron once... never had problems with 76... used mobile and texaco a few times and had no noticable problems. of course when i heard knocking, it had been a few months without octane boost.
BoostinDC2's Avatar
Default Re: Shell gasoline wreaking havoc on FI Hondas? (csufweed)
chevron,76, or mobil
Old Jul 1, 2002 | 11:04 PM
PyroVTEC's Avatar
New User
Default Re: Shell gasoline wreaking havoc on FI Hondas? (BoostinDC2)
What, no VP fuel?
Yeah, I think I'll be hittin up Unocal a liiiiiitle bit more.... no sense in blowing up an engine...
iwill
Aug 1, 2010 10:18 PM
93preludes
Feb 5, 2006 07:23 PM
