Leaking Gas :(
Leaking gas at the fuel rail. Where the fuel hose comes off from the filter to the rail and is bolted on. If your looking from the front of the engine:
Left side-Large Nut holds on the washers and fuel hose
------leaking fuel right here...
-Washer...ive relaced the washer with a new one and still leaks.
-Fuel Hose
-Another washer
-Fuel rail
After i took everything off again to examine the issue, the new washer i had JUST put on...was gone...im guessing a crush washer? How can i fix this crap? My mileage is sucking real bad
-Fuel Hose
-Another washer
-Fuel rail
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror »</TD></TR><TR><TD CLASS="quote">You need to buy the white seal tape, and wrap it around the bolt.</TD></TR></TABLE>
That is a banjo bolt. Teflon tape would block the flow.
OP, replace the crush washers and torque to the proper spec. Inspect all surfaces for scratches, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">
OP, replace the crush washers and torque to the proper spec. Inspect all surfaces for scratches, etc.</TD></TR></TABLE>
I ordered some new washers today, should be in tomorrow
lol @ trying to band-aid fuel leaks.
Accord15
Dec 9, 2002 02:04 PM
