1st gear
my car looses all its power in first or second gear about once a week.. the motor is a d16y7 and it was recently put in has about 80k on it i have no cel's.... and i already checked my cat and o2 sensors... only thing i can think of is fuel filter or somethiing... any help is appreciated.. oh and new spark plugs also and still keeps doing it every so often
Do you think you can be a bit more specific?
Like it doesn't have the power it should in 1st or 2nd? Or is it bogging down, or what?
Did you do a tun-up (plugs, wires, cap, and rotor)?
well the car just seems to bogg down and lose all the power in those gears everyonce in a while and i have new wires and plugs but not dizzy... but im not trying to get a new dizzy when i believe the one i have now is working just fine
Im not saying that its not the dizzy, but to say that honda distributers are shitty i would say that is way off. Mine works just fine and im running with a turbo. I would check the dizzy. and does it happen when your starting out from a stop or does it happen when your downshifting?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-V Turbo »</TD></TR><TR><TD CLASS="quote">Im not saying that its not the dizzy, but to say that honda distributers are shitty i would say that is way off. Mine works just fine and im running with a turbo. I would check the dizzy. and does it happen when your starting out from a stop or does it happen when your downshifting?</TD></TR></TABLE>
it happens from stops like off redlights and coming out of a parking spot or something one of my friends has been threw 4 dizzies
it might be that
it might be that
wow that is alot of dizzy's but it very well could be that. i would replace the fuel filter also if you haven't already done it. and what year is this car sorry if you have already posted it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green »</TD></TR><TR><TD CLASS="quote">my car looses all its power in first or second gear about once a week.. the motor is a d16y7 and it was recently put in has about 80k on it i have no cel's.... and i already checked my cat and o2 sensors... only thing i can think of is fuel filter or somethiing... any help is appreciated.. oh and new spark plugs also and still keeps doing it every so often</TD></TR></TABLE>
sounds like a "slow" o2s...
the car is a 2000 civic lx and yess the o2's have been checked... im just gonna buy a new dizzy and fuel filter... by the way what does a new dizzy run these days for a 2000 civic lx d16y7???? around 100 bucks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green »</TD></TR><TR><TD CLASS="quote">the car is a 2000 civic lx and yess the o2's have been checked... im just gonna buy a new dizzy and fuel filter... by the way what does a new dizzy run these days for a 2000 civic lx d16y7???? around 100 bucks?</TD></TR></TABLE>
You can probably find a used one for $100. If you go to Advance Auto or Autozone or something it's going to be closer to $200 + core.
However, your problem is most likely just the ignition coil, not the whole distributor. I'd check it before you drop a bill or two on something you don't need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
However, your problem is most likely just the ignition coil, not the whole distributor. I'd check it before you drop a bill or two on something you don't need.</TD></TR></TABLE>
thanks for the info bro i'll def check if its the ignition coil
