B16A2 OBD2B into 1996 Civic DX OBD2A (wiring clash)
I have dropped my old Si motor into a 96 DX. I was told that the dash wiring would not plug up directly to my Stock Si ECU. (OBD2B vs. OBD2A) I do not want to rewire the whole dash so how would i go about this? (jumper harnesses, switching ecu, or using different engine wiring harness) If one or more of the above are possible, please tell me what I would have to do to make it work.
Thanks
-ixoiiiiviviiivi
Thanks
-ixoiiiiviviiivi
The 99=00 harness will not work because the "green plug" is different for the 2a and 2b cars. You can get a P30 from a 95-97 Del Sol VTEC. Yes, you could use a P28 but you'd want to get it socketed and have a chip made for your engine.
Ryan
Ryan
here is what you need - http://locashracing.com/store/...id=47
but check around you may find it cheaper
EKcivicEK
Oct 25, 2009 09:00 AM
goldbrick
Jun 27, 2003 01:41 PM
