help with h22 swapped ek hatch
I am verry sorry if this is in the wrong section...
I have a 96 ek hatch, with a h22a1, obd2-1 jumper harness
I have it on a p13, but I dont have a knock sensor so I get no vtec.
I also have a p30 that was chipped with crome.
I recently had a friend re-burn the chip to disable the knock sensor, vtec temp sensor, and other things. and I still have no vtec.
the wire from the vtec selenoid, and another vtec wire, are wired right into the obd1 side of the harness. I have checked the wiring and everything seems to be the way it should.
and I got nothing. the PO did all the wiring and the swap, he said the only time he had vtec working was when the car was on a chipped p13, but I thought you couldnt chip p13s.......
I I should just be able to install a knock sensor and be good to run that p13 right?
I am new to all this stuff.
thanks
thanks
if the ecu is looking for a knock sensor and it is not present, vtec will NOTwork.
as far as your situation goes, yes if u install the sensor and all other provisions are working, then it will run the way its intended to.
Modified by Malakai at 5:12 PM 10/30/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burgiop »</TD></TR><TR><TD CLASS="quote">I don't think not having a knock sensor would take out the V-tec. Also P13 are able to be chipped if you run it through a socket.</TD></TR></TABLE>
No knock sensor = No VTEC
I bought a phearable chip for my p30 to run the h22,
and I still get no vtec....
what could be keeping me from engaging vtec?
the chip in the ecu doesnt need a knock sensor, and isnt throwing any codes.
could it be the vss? or what
I am boggled.......
I am boggled.......
