msd 6AL and blaster coil 2 install
Old Oct 29, 2007 | 06:05 PM
korndog's Avatar
Default msd 6AL and blaster coil 2 install
i have a buddy who ordered this stuff for his b20 vtec hatch. His hatch was totalled so i more or less got the stuff for nothing. I have a msd 6al box and blaster 2 coil and a distributor cap. A few questions:
Will the distributor cap fit?
If not will the stock one be able to modify?
The msd box has a spot for rpm pills. If i leave them out will the stock rev limit still work?
If ne one has this install or close to it, was it difficult to install?
Are there ne guides specifically to install this stuff in an integra with pictures?
Thanks in advance
Old Mar 20, 2008 | 09:39 PM
8point6's Avatar
Default Re: msd 6AL and blaster coil 2 install (korndog)
edit
Old Mar 20, 2008 | 10:58 PM
blowngsr1's Avatar
go to msd's web site they have the install i had the msd boost timing management and i removed it because i kept going threw ignitors like water 4 i 3 months the stock ignition is good for 400 hp and with an external coil to like 500 hp just my .02$ worth
Old Apr 14, 2008 | 09:50 AM
ku's Avatar
ku
if u purchase 6AL will it come with launch control?
or will u have to purchase the the soft touch controll also?
do u need a msd dizzy cap to run the 6AL?
Old Apr 14, 2008 | 12:01 PM
Hayasa15's Avatar
does anybody use the ballast resistor on honda setups with msd?
lshatchcx18
Mar 10, 2004 10:44 PM
tnsxsear1
Nov 16, 2003 10:31 AM
