Broken Motor Mount Bolts
I have a 89 crx with a b18 vtec swap not too familiar with these motor so i dont know what every one calls it any ways the guy i bought it from broke the driver side motor mount bolts off in the block does anyone have any ideas to fix it or know if there is another type of motor mount i can use with that set up
i dunno about b seris, but i know on the H, that whole plate thing where the one stud is on, and the other bolts on, can be replaced. You have to take the engine outta the car and take off all the timing belt covers and stuff. I THINK
you have to replace the mount. Hasport and Avid are good motor mount makers for motor swaps. But you need the OEM bracket with bolts that are attached to the motor behind the timeing cover. you can replace the bolt but if you are going to go through all the trouble of changeing the bolt. Its cheap. Just replace the whole thing. Good luck
jdmjay04
10
Dec 16, 2004 10:56 AM
