Shipping dropped motor- need advice on damage
Old Oct 29, 2007 | 03:51 PM
2fastGSR's Avatar
King of the One Liners
Default Shipping dropped motor- need advice on damage
I put up a thread a few months ago about all the carnage that Seko Worldwide did to my H22. Needless to say it has been a PIA getting all the parts that were damaged.
Well i started to do the swap and what do you know i find more damage.
Took off the crank pulley and lower timing cover to inspect and I found a timing belt tensionor (sp?) snapped off. Not only that but it snapped off part of the block where it mounts. what can i do here ? have the little piece welded back on ? just use a longer bolt with a spacer? i mean this is tough because it basically keeps pressure on the TB so i dont want to go ghetto if you know what i mean- see pics
any insight would be greatly appreciated.
thanks
Sorry for the crappy cell phone pics- at the shop now and its all i have available !!
Old Oct 29, 2007 | 03:59 PM
Acidcrakker's Avatar
Default Re: Shipping dropped motor- need advice on damage (2fastGSR)
This wont help you out, but is that a manual or automatic tensioner?
Old Oct 29, 2007 | 04:00 PM
JonGP4's Avatar
Maybe i'm seeing the picture wrong, but isn't that on the Water Pump? Could you just get a new Water pump and this would fix the problem? That isn't actually part of the block, unless i'm seeing that picture wrong.
Old Oct 29, 2007 | 04:02 PM
xxmastermindxx's Avatar
Default Re: (JonGP4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe i'm seeing the picture wrong, but isn't that on the Water Pump? Could you just get a new Water pump and this would fix the problem? That isn't actually part of the block, unless i'm seeing that picture wrong.</TD></TR></TABLE>
x2
that's on your water pump, you should be able to pull it off and just replace it.
Old Oct 29, 2007 | 04:08 PM
ChrisRicketts's Avatar
Default Re: (xxmastermindxx)
yep....you really needed to replace it anyway. congratulations!! you can breath now.
p.s.- if you have an auto tensioner on there now would be the perfect time to convert to a manual tensioner.
Old Oct 29, 2007 | 04:17 PM
2fastGSR's Avatar
Default Re: (ChrisRicketts)
yeah i just came back in to edit the post- i guess my heart was in my throat so much that i didnt realize it was on the water pump.
Thanks for the quick responses guys i really appreciate it
PRELUDEGURL98
Jul 17, 2009 05:01 PM
M2B4
Jan 7, 2007 04:25 PM
mikegeezy
Mar 29, 2006 06:10 AM
T-Mo
12
Aug 30, 2004 07:59 AM
_Endless_
May 12, 2003 07:22 PM
