connecting a scanner to a chipped ecu?
Old Oct 29, 2007 | 02:37 PM
RACEPAK's Avatar
Default connecting a scanner to a chipped ecu?
hello everyone,
i was just wondering,
did anyone of you crome chipped guys ever tryed to connect your car to a obd scanner?
i tryed to connect my car to the scanner today and it didnt recognized the ecu, it asked me if my vehicle is electric :S (i work at honda, its a OEM scanner )
j12 is cut,
should i solder it back in and give it another shot?
thanks
Old Oct 29, 2007 | 03:58 PM
silentbeatz's Avatar
more info on the car? if you're using a obd2 to obd1 jumper harness, the obd2 connector won't read.
Old Oct 29, 2007 | 04:23 PM
sicones's Avatar
Default Re: (silentbeatz)
you need an OBD1 scanner, they're vehicle specific, expensive and not widely available as compared to OBD2 scanners
and if your car was obd 2 and it was converted using a jumper harness, I don't think it will ever work
Old Oct 30, 2007 | 07:46 PM
RACEPAK's Avatar
Default Re: (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">you need an OBD1 scanner, they're vehicle specific, expensive and not widely available as compared to OBD2 scanners
and if your car was obd 2 and it was converted using a jumper harness, I don't think it will ever work</TD></TR></TABLE>
sup. the scanner i'm using is a OEM pgm-fi scan tool,( i work at honda)
the scanner is a honda ONLY scanner for all the years,
my entire harness is obd1, and i'm using the 3 pin obd1 connector... give me a brake guys i kinda know what i'm doing, it just cant read it,
Old Oct 31, 2007 | 12:46 AM
suicide_shift's Avatar
* B A N N E D *
Default Re: (RACEPAK)
never had the oem scan tool or had one but i knew the paper clip trick worked for me.....accidently cut wire?
Old Oct 31, 2007 | 02:18 AM
RACEPAK's Avatar
Default Re: (suicide_shift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suicide_shift &raquo;</TD></TR><TR><TD CLASS="quote">never had the oem scan tool or had one but i knew the paper clip trick worked for me.....accidently cut wire? </TD></TR></TABLE>
This way it works for me too, (there are no cel's/tdc's) i just wanna watch the data list...
Old Oct 31, 2007 | 04:10 AM
JKov240's Avatar
At our shop we use a Snap-On Solus scanner that comes with all of the OBD1 vehicle specific connectors (works with OBD2 as well)...you can't scan a chipped ECU for whatever reason, it just freezes up the scanner (ours at least). Sad, but true...
Old Oct 31, 2007 | 10:44 AM
sicones's Avatar
Default Re: (JKov240)
if you want to just see the data and datalog with your chipped ecu you can do that with a laptop and the freelog program
https://sourceforge.net/projec...45285
Old Oct 31, 2007 | 10:47 AM
fmrprojects's Avatar
have you tried just jumping the connector and reading the flashes. if you have a solid light that wont blink, then you have a bad ecu, or a bad chip. i seen it happen many times
Old Oct 31, 2007 | 11:48 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">
This way it works for me too, (there are no cel's/tdc's) i just wanna watch the data list...</TD></TR></TABLE>
As far as I know, the typical OBD1 scanner does not work on a chipped ECU. all though I could be wrong, try it with J12 in place. Logically it's in place from the factory... if it doesn't try it with J1 pulled. it has to start working some time.
IMO the best way to go is to datalog directly from CN2.
egbaby
Mar 1, 2008 06:52 AM
Civic98KH
Mar 11, 2007 09:21 PM
92civic_si
16
May 6, 2004 02:50 PM
shawnc21
Jan 9, 2003 11:21 AM
