Suspension & Brakes Theory, alignment, spring rates....
APEXi N1 type PRO?
Old Oct 29, 2007 | 01:49 PM
DA6mike's Avatar
Default APEXi N1 type PRO?
Can anyone tell me how to adjust them,which way to turn and which ***?
Old Oct 29, 2007 | 06:13 PM
EGD's Avatar
EGD
Default Re: APEXi N1 type PRO? (DA6mike)
the very top ***, clockwise hardn the dampenin, anticlockwise to soften
Old Oct 30, 2007 | 09:54 AM
DA6mike's Avatar
Default Re: APEXi N1 type PRO? (EGD)
THX EGD.So i pull top one and turn?How many clicks,I tryed and there is no stoping,it didnt stop half way
Old Oct 30, 2007 | 11:23 AM
B16B_coupe's Avatar
HRD PKR
well if they the same as exv, you screw the adjusting **** all the way down then turn it.... it should move a ton.. but it will move from soft to hard..
i can take a pic for you tonight if you would like
and to adjust the height you use the apexi wrench's and turn the part under the spring to the right. to raise the car. do the opposite to lower it
Old Oct 30, 2007 | 11:30 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: APEXi N1 type PRO? (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">and to adjust the height you use the apexi wrench's and turn the part under the spring to the right. to raise the car. do the opposite to lower it</TD></TR></TABLE>
The dampers pictured above have separate preload adjustment, so you turn the actual threaded portion of the shock body to raise or lower, and use that lowest locking ring to lock it into place. The rings under the springs are used for preload adjustment only.
Old Oct 30, 2007 | 11:55 AM
B16B_coupe's Avatar
HRD PKR
Default Re: APEXi N1 type PRO? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
The dampers pictured above have separate preload adjustment, so you turn the actual threaded portion of the shock body to raise or lower, and use that lowest locking ring to lock it into place. The rings under the springs are used for preload adjustment only.</TD></TR></TABLE>
THANKS
Old Oct 30, 2007 | 12:02 PM
DA6mike's Avatar
thx for this,but i need to know how to adjust hard and soft
Old Oct 30, 2007 | 12:05 PM
B16B_coupe's Avatar
HRD PKR
if you read i said,
tighten the long piece all the way down on the strut top
then adjust the smaller one on top left and right to make it softer or harder
it shouldn move a whole lot.. but will maybe like ten clicks each way maybe
Old Oct 30, 2007 | 12:09 PM
DA6mike's Avatar
I have also Tein SS and on them yu know when tu stop adjust damping,**** comes to stop at half way point,turn back slightly until it clicks into place.But on Apexi can feel that
Old Oct 30, 2007 | 03:10 PM
Joey.'s Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGD &raquo;</TD></TR><TR><TD CLASS="quote">the very top ***, clockwise hardn the dampenin, anticlockwise to soften
GSR-T-
Jul 7, 2003 12:06 PM
POLLO
Oct 12, 2002 08:32 PM
EVOTHIS
Jun 24, 2002 10:45 AM
