Bass Drum Beat
Old Oct 29, 2007 | 12:05 PM
th3dynasty's Avatar
Default Bass Drum Beat
hi i have a b16 and when i rev the engine to about 1500 rpm it starts to make this bass drum beat this only happens between 1500 and 2000 rpm my check engine light also turned on when this started.anyone know what could be causing this. i also have this one sensor that is not hooked up to anything it is mounted on the fuel rail i will post a video and pictures later if anyone needs them thanks
Old Oct 29, 2007 | 12:10 PM
hatchling37's Avatar
Default Re: Bass Drum Beat (th3dynasty)
What code is it? What sensor is unplugged? You should go do a little reading in the Civic forum - specifically the CEL thread. Pdiggity did an awesome write-up. You'll find a lot of info just looking in all the FAQ sections that are stickied in most all of the forums.
GHR27937
Jan 31, 2014 07:00 AM
TaikiDC5
Jul 30, 2011 01:17 PM
myr10
Jan 30, 2011 03:37 AM
ricmac007
20
May 15, 2009 10:11 PM
typeRcoupe32
May 4, 2008 09:13 AM
