FS: 91 DX hatch w/b16- N.IL
Old Oct 29, 2007 | 11:13 AM
civicflow's Avatar
Default FS: 91 DX hatch w/b16- N.IL
FS/TW: 91 Honda Civic hatchback with obd0 B16 motor/trans
Motor runs perfect. Trans has 3rd gear grind. No rust on body of car. Car came from Kentucky. Body has 218,000 miles. Motor/tranny have about 80,000 miles.
$3000 OBO Price lowered
The Good:
-New timing belt and valve cover gaskets
-New Competion Clutch
-GSR armrest and shifter cover
-Semi-wire tuck
-Odyssey 680 battery relocated below old stock mounting point
-EG intake wrapped with header wrap
-P30 intake manifold(looks cleaner than the old obd0 one)
-Full Si interior except guage cluster
-Autometer 3 1'2 inch tach
-Drivers seat has a tiny tear from wear but otherwise good condition
-Converted to obd1 w/P06 ecu running a B16 Map
-New distributor
-New starter
-VW front lip
-Invidia cat back exhaust with Magnaflow cat
-stock header w/heat shield
-BFG drag radials mounted on 89 CRX SI rims. I also have three more 89 CRX Si rims and 4 steelies with good tires. I was going to put 2 of the tires on the CRX Si rims but havn't done it yet.
The Bad:
-High Rpm Third gear grind
-Needs new suspension bushings installed and balljoints(which I will include not installed)
-Has EG DX front knuckles and the brakes are about gone
-Paint is faded and passenger side front fender has a dent
-There is some surface rust in the trunk from a water leak. pic below
-Wiring is all intact but some wires could be soldered. I don't have power in my garage.
Extra parts that will come with but not installed:
-Energy suspension master bushing kit
-91 4 door EX front knuckles/calipers w/new lower balljoints pressed in
-New upper control arms, inner/outer tie rods, and sway bar links
-New poly radius rod bushings
Feel free to ask any questions by PM. I am located in by Rockford, IL
Modified by civicflow at 3:25 PM 11/11/2007
Old Oct 29, 2007 | 12:42 PM
stevieteg's Avatar
Default Re: FS: 91 DX hatch w/b16- N.IL (civicflow)
not bad
Old Oct 29, 2007 | 04:55 PM
94sisol's Avatar
Default Re: FS: 91 DX hatch w/b16- N.IL (stevieteg)
Pmed.
Old Oct 29, 2007 | 06:47 PM
ls-v*2's Avatar
Default Re: FS: 91 DX hatch w/b16- N.IL (94sisol)
Old Oct 29, 2007 | 08:15 PM
civicflow's Avatar
Default Re: FS: 91 DX hatch w/b16- N.IL (ls-v*2)
thanks for the bumps.
someone buy this.
Old Oct 30, 2007 | 08:23 AM
civicflow's Avatar
up.
Old Oct 30, 2007 | 04:35 PM
dxtosirex's Avatar
clean car.
Old Oct 30, 2007 | 08:20 PM
civicflow's Avatar
Default Re: FS: 91 DX hatch w/b16- N.IL (dxtosirex)
I have stuff for sale in sig that I would give discounts on if purchased with this car. Check em out!
Old Oct 31, 2007 | 06:27 AM
civicflow's Avatar
up
Old Oct 31, 2007 | 06:34 AM
aarontrini85's Avatar
thats sad to see this go youve been working on this car for a while but you got to do what you got to do good luck man
Old Oct 31, 2007 | 07:19 AM
civicflow's Avatar
Default Re: FS: 91 DX hatch w/b16- N.IL (aarontrini85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarontrini85 &raquo;</TD></TR><TR><TD CLASS="quote">thats sad to see this go youve been working on this car for a while but you got to do what you got to do good luck man </TD></TR></TABLE>
yeah, it sucks but I would rather pay off my bills now so I don't have to be scraping by if I get laid off.
There is always more time to build another car...
Old Oct 31, 2007 | 10:26 AM
civicflow's Avatar
Added more stuff for sale in sig that I can give discounts on if bought with this civic!
Old Nov 1, 2007 | 07:16 AM
civicflow's Avatar
up
Old Nov 2, 2007 | 10:39 AM
civicflow's Avatar
up
Old Nov 2, 2007 | 08:07 PM
Eugene87's Avatar
bump for sweet *** car, looks like my old b16 4th gen, i want it
Old Nov 2, 2007 | 10:08 PM
civicflow's Avatar
Default Re: FS: 91 DX hatch w/b16- N.IL (Eugene87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eugene87 &raquo;</TD></TR><TR><TD CLASS="quote">bump for sweet *** car, looks like my old b16 4th gen, i want it </TD></TR></TABLE>
Let's make a deal. I have extra parts I can sweeten the deal with in link in my sig.
Old Nov 3, 2007 | 08:28 AM
Eugene87's Avatar
if my gsr swap sales ill have the cash! i let you know when it sales
Old Nov 3, 2007 | 09:56 AM
civicflow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eugene87 &raquo;</TD></TR><TR><TD CLASS="quote">if my gsr swap sales ill have the cash! i let you know when it sales </TD></TR></TABLE>
Let me know!
Old Nov 3, 2007 | 05:38 PM
civicflow's Avatar
up
Old Nov 4, 2007 | 02:11 PM
dxtosirex's Avatar
Old Nov 5, 2007 | 08:00 AM
civicflow's Avatar
edit
Modified by civicflow at 3:23 PM 11/11/2007
Old Nov 5, 2007 | 08:56 AM
dxtosirex's Avatar
I wish I had the money. I'd walk to your house right now a pick it up!
Old Nov 6, 2007 | 09:09 AM
dxtosirex's Avatar
I got to ride in this car. Pulls strong Someone buy it, its too hot for this price!!!
Old Nov 7, 2007 | 09:39 AM
civicflow's Avatar
up
Old Nov 8, 2007 | 07:06 AM
civicflow's Avatar
BUY ME
