98 V6 accord alternator issues
Old Oct 29, 2007 | 10:45 AM
typeR#0427's Avatar
Default 98 V6 accord alternator issues
ok, so i usually am working on my R, the accord is very reliable. however i have had to replace the alternator 2 times in the last 2 years. this seems a bit more than normal.
also as soon as i got the alternator on saturday the power steering pump starting sounding like ****? my wife normally drives the car and said it had been making noise, but it went from a small sound to a very bad one and it obviously needs replacing too.
my question is: have you other V6 owners had any similar expieriences with these? i was always worried about the tranny, hahaha, its solid.
the car did just click over 130K so im thinking its normal maintenance, but advice is appreciated.
Old Oct 30, 2007 | 10:24 AM
typeR#0427's Avatar
Default Re: 98 V6 accord alternator issues (typeR#0427)
please
Old Oct 30, 2007 | 04:41 PM
YeuEmMaiMai's Avatar
extend your wires by 4" and install an 130amp oddessy alt (V6 model)
or
install the alt from the 7th gen V6 accord or a TL/CL.
6th gen accords use a DELPHI alt and those things rarely last 100K I had to replace mine at 96K.........
Old Oct 30, 2007 | 05:53 PM
hayabusa160's Avatar
Default Re: 98 V6 accord alternator issues (YeuEmMaiMai)
its a common problem for those altnators to go.
you can try and replace the ps fluid and see what happens. go hit upt he honda dealer and pick up 2 bottles.
see if it help if not you will need a new pump.
Old Oct 30, 2007 | 11:25 PM
typeR#0427's Avatar
Default Re: 98 V6 accord alternator issues (hayabusa160)
i assumed it must be a common problem. i did buy a new honda one from the stealership. hopefully it will last for a while, (doubt it)
as far as the PS pump, it sounds like its grinding really bad, added fluid and still no love.
Old Oct 31, 2007 | 04:13 AM
when i had my 98 v6 alt replaced honda dealer told me 3yr 36k warranty on replacement. those things are a PITA to put in
Old Oct 31, 2007 | 09:31 AM
typeR#0427's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">when i had my 98 v6 alt replaced honda dealer told me 3yr 36k warranty on replacement. those things are a PITA to put in </TD></TR></TABLE>
my knuckles couldnt agree with you more. other than the timing belt cover bolts, those are really a beotch.
as far as the odyssey battery, just more amps and different manufacture?
Old Oct 31, 2007 | 01:42 PM
its not that bad if you take the radiator fan off.
Old Oct 31, 2007 | 08:03 PM
typeR#0427's Avatar
i did remove the fan, just didn't have the tension pulley tool, so i had to "improvise" and that thing is loaded.
and BTW thanks for the forum dig link, it'll come in handy
Old Oct 31, 2007 | 09:13 PM
the oddessy is a denso unit and doe snot crap out like them GM stuff does.
Biglbg
Jun 20, 2019 05:31 PM
Polish_dude
Sep 11, 2006 06:37 PM
Mangotreemechanic
May 23, 2006 11:58 PM
syvlvr
Suspension & Brakes
Nov 11, 2005 09:22 PM
briq4
Dec 16, 2003 06:22 PM
