Suspension & Brakes Theory, alignment, spring rates....
HELP!!!CAMBER WEAR
Old Oct 29, 2007 | 10:19 AM
POWerTuner's Avatar
Default HELP!!!CAMBER WEAR
I have an eg with some coilovers. The car is sitting pretty low. One tire was blown from the camber wear. I am thinking about changing cambers. Is that neccessary? The camber wear happens to all four tires.HELP!!!!!
Old Oct 29, 2007 | 10:29 AM
Tyson's Avatar
Default Re: HELP!!!CAMBER WEAR (POWerTuner)
you needed an alignment. that tire wear was not caused by the change in camber, but from the change in toe that also happens when you lower a car.
buy new tires and get a 4 wheel alignment.
dont waste you money with a camber kit. it wont help.
Old Oct 29, 2007 | 10:57 AM
teggsr925's Avatar
Default Re: HELP!!!CAMBER WEAR (Tyson)
i have the same problem, did some research and finding out that toe is the problem, camber kits really dont help that much
get new tires n alignment n ull be good
Old Oct 29, 2007 | 11:39 AM
POWerTuner's Avatar
Default Re: HELP!!!CAMBER WEAR (teggsr925)
thanks alot guys. appreaite it.
Old Oct 29, 2007 | 02:17 PM
shadohconspiracy's Avatar
wouldnt place like les schwab or w/e wont align it for you because they can't do the camber? can you just tell them "i don't care about camber, just align the toe?
Old Oct 29, 2007 | 02:20 PM
Tyson's Avatar
Default Re: (shadohconspiracy)
i dunno why ppl ever have a problem.
ive never had a problem with telling a shop to just align the toe.
most alignment techs i talk to do know that toe is what wears tires unevenly. its only ppl on honda tech that insist its the camber.
Old Oct 29, 2007 | 02:40 PM
bmoua's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">i dunno why ppl ever have a problem.
most alignment techs i talk to do know that toe is what wears tires unevenly. its only ppl on honda tech that insist its the camber. </TD></TR></TABLE>
So when you get a alignment you would have to tell the alignment tech to set your toe to zero correct? I'm just wondering why wouldn't alignment techs know this? I've been running my skunk2 front camber kit w/ rear washer trick and i've seen no wear what so ever.
I"m not trying to say your wrong Tyson, but im just speaking from personal experience.
* Note- i drive roughly 80-100miles a week, 2.0-2.5inchs all around
Old Oct 29, 2007 | 03:12 PM
Tyson's Avatar
Default Re: (bmoua)
and did you also get your toe corrected?
how did you adjust your camber?
you should know that when you adjust the camber positive, it also brings the alignment back in the direction that it originally was. but without measuring anything, youll never know know where it finally lies.
ride height affects camber and toe.
camber affects toe.
toe affects tire wear.
Old Oct 29, 2007 | 04:09 PM
bmoua's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">and did you also get your toe corrected?
camber affects toe.
i just took my car to a reputiable alignment shop and had them do my alignment for me. The only thing i did was bolt up my sk2 front camber kit.
So as i asked above, whats the process in a regular alignment? If your not equipped with a camber kit do they adjust the toe? Or what other parts of the suspension do they adjust?
Old Oct 29, 2007 | 04:45 PM
Tyson's Avatar
Default Re: (bmoua)
for a civic, its just adjust toe.
and thats all you needed. forget that they adjusted your camber with your new camber kits. it was the toe adjustment that has saved your tires thus far.
so please stop saying that because you put a camber kit on, and got an alignment done, that the camber kit has saved your tires. it was the toe alignment.
Don JD
10
Sep 23, 2009 08:04 AM
gt3civic
May 14, 2007 07:27 PM
alex_s817
Apr 17, 2006 07:51 PM
90si-racer
Oct 17, 2004 09:36 PM
spork sport
19
Mar 12, 2002 09:02 PM
