JRSC + UR pulleys = Where do I find a belt?
Old Oct 29, 2007 | 07:52 AM
CBoardman's Avatar
Default JRSC + UR pulleys = Where do I find a belt?
Ive got a 98 civic with a JRSC and Unorthadox pulley set. After comparing stock Alt length to the underdrive length. The supercharger with the high boost pulley takes a 1245mm belt. with the UR alt pulley, it looks like Ill need another ten mm, as the belt is so tight now, it rubs the cover and the tensioner is as loose as the belt will let it be. So I need about another 10mm in length so the tensioner can move so that the belt doesnt rub. Does anyone know where I can find a 3 rib belt about 1255 MM long? I called bando and after 1245 the next belt they make is a 1500mm length. thats a little much.. anyone have this problem? Id rather keep that pulley on there than switch back to the stock pulley, but if thats my only option... thats my only option
Old Oct 29, 2007 | 10:10 AM
dbiker207's Avatar
Default Re: JRSC + UR pulleys = Where do I find a belt? (CBoardman)
get rid of the underdrive pulleys they dont do ****
end005
Aug 31, 2010 06:42 PM
jlfrnce
Aug 11, 2008 04:41 PM
jbs
Mar 10, 2004 10:25 AM
jbs
Mar 10, 2004 09:56 AM
CRVRX
Apr 29, 2003 10:19 AM
