h22 auto vs f23 auto transmissions?
Old Oct 29, 2007 | 07:48 AM
russlan44's Avatar
Default h22 auto vs f23 auto transmissions?
My brother in laws 99 accord auto tranny is going out, i have a space jdm h22 auto tranny and i was wondering if they would fit? they look a like.
Old Oct 29, 2007 | 08:19 AM
sony224422's Avatar
Default Re: h22 auto vs f23 auto transmissions? (russlan44)
yes it will fit, but the gear ratios are different. he will be able to accelerate faster but loose top speed. he will also sit at a higher rpm on the highway
Old Oct 29, 2007 | 10:43 AM
russlan44's Avatar
Default Re: h22 auto vs f23 auto transmissions? (sony224422)
ok what about the sensors?
Old Oct 29, 2007 | 11:39 AM
sony224422's Avatar
im not sure.
Old Oct 29, 2007 | 06:15 PM
YeuEmMaiMai's Avatar
should bolt right up..........4K at 70 is gonna suck and so is your gas milage........
Old Oct 29, 2007 | 06:35 PM
russlan44's Avatar
Default Re: h22 auto vs f23 auto transmissions? (YeuEmMaiMai)
yeah i know that from owning a prelude, i hate driving it on freeway, takes so much gas, and to work its only freeway for me 80miles a day just for work and back. i just hope the plugs and connectors will fit so i wont be with extra left over, ill fill him in on info about higher RPM's and his gas millege
Old Oct 29, 2007 | 11:54 PM
Twixle's Avatar
ate my pixel
Do you have the TCU for the H-transmission?
Old Oct 30, 2007 | 12:02 AM
russlan44's Avatar
Default Re: h22 auto vs f23 auto transmissions? (Twixle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twixle &raquo;</TD></TR><TR><TD CLASS="quote">Do you have the TCU for the H-transmission?</TD></TR></TABLE>
whats a TCU?
Old Oct 30, 2007 | 12:08 AM
Twixle's Avatar
ate my pixel
transmission control unit, the equivalent of an ECU that controls auto transmissions. I'm not sure if they were using them in '99, does your H tranny have and loose plugs on it?
Old Oct 30, 2007 | 12:11 AM
russlan44's Avatar
at this point its just full clip just picked it up on sat
Old Oct 30, 2007 | 12:13 AM
Twixle's Avatar
ate my pixel
Interesting. Are you planning on swapping the engine into your car?
Old Oct 30, 2007 | 12:15 AM
russlan44's Avatar
the engine is going in with h23 trany into this
and heres my DD
Old Oct 30, 2007 | 12:24 AM
Twixle's Avatar
ate my pixel
Nice, I love H-powered hatches. There was a SC/H22 hatch on here, all stock on the outside.
Old Oct 30, 2007 | 03:20 AM
TouringAccord's Avatar
H-T Order of Merit
not trying to take your thread further off topic but why not use a B or D series tranny with suitable adapter plate? Would be a lot easier to install, wouldn't have to cut the chassis to install the shifter and cables. Unless you want the gearing of the H series over that of the B series.
Old Oct 30, 2007 | 07:28 AM
jweller's Avatar
Default Re: h22 auto vs f23 auto transmissions? (TouringAccord)
yeah it bolts right up, but I'm not sure if it will shift. 98 - 02 accords have the TCU integrated as part of the ECU. it's just an extra plug that isn't on the 5spd ECU. I think, not sure, that your h22 has a separate TCU to shift the tranny. I have no idea how that would work. I doubt that you would be lucky enough that the electronics would be plug and play, but I'm just speculating. Mechanically, your golden though.
and giant block of wood jackstands FTMFW
goku335
Oct 15, 2007 03:51 PM
Newbiemoney
Oct 27, 2005 01:00 PM
Pootie
Apr 28, 2005 06:33 PM
loki2323
Oct 11, 2002 09:11 AM
