my car it been burning GAS what might be wrong? PLEASE HELP
for some reason my car been burning gas...like i fill up the tank and i dont drive much..only from work to home..2day's 1 bar of my gas is gone..what might be wrong??? O2 sensor ? or wat else please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJNauTicz »</TD></TR><TR><TD CLASS="quote">for some reason my car been burning gas...like i fill up the tank and i don't drive much..only from work to home..2day's 1 bar of my gas is gone..what might be wrong??? O2 sensor ? or what else please help</TD></TR></TABLE>
This means nothing!!! Give us a little more info like mpg its not hard to figure out. fill the tank reset your trip odometer. When you fill up again divide the number of miles driven by the gal to fill gives you mpg. Over the course of a few tanks you can get an average. Also driving style can effect mpg quite a bit, what car and engine, any mods to the engine like running boost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 »</TD></TR><TR><TD CLASS="quote">
This means nothing!!! Give us a little more info like mpg its not hard to figure out. fill the tank reset your trip odometer. When you fill up again divide the number of miles driven by the gal to fill gives you mpg. Over the course of a few tanks you can get an average. Also driving style can effect mpg quite a bit, what car and engine, any mods to the engine like running boost?</TD></TR></TABLE>
yeah if you just start your car up and go man your goin to get worse gas mileage, cause when the car is cold it burn's more fuel and cause's more engine wear..
now do what i quoted above to see what your mpg is.
fuel leak somewhere? Im guessing you get the smell of gas when you get out of your car right? done any recent maint work? fuel filter? injectors? take off your fuel rail for any reason?
yea check to see if your leaking gas and also make sure you warm up your car b4 you go like coupe said it does burn alot more gas if you start up and go...
also instructor has a good point make sure you give us more info.
i know what you mean. that happened to my car also. check the FUEL INJECTORS. they might be pushing in too much gas. check that out.
sorry for the little details..
ok..let me give out more details..
1) normally i dont realy warm up my car..i start and go..
2) no fuel filter or fuel rail work ...only injectors
i have a 93 honda civic hatch with a integra b18 engine .
also yea smell gas around the car...but i check all over the engine..and so.i dont see no leak... ....... so in this case wat should i do to check the problem?
The REAL TEST.... Constantly strike matches around your car when parked, If it comes Ablaze... Yeah, I think you got a fuel leak somewhere....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJNauTicz »</TD></TR><TR><TD CLASS="quote">sorry for the little details..
also yea smell gas around the car...but i check all over the engine..and so.i dont see no leak... ....... so in this case wat should i do to check the problem?</TD></TR></TABLE>
well what exactly did you do with the injectors?
dude, check the injectors, i think they might be spitting fuel into the engine, causing you to burn gas. I had this happen to a friend once, it was his injectors.
Damn internal combustion engines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch »</TD></TR><TR><TD CLASS="quote">dude, check the injectors, i think they might be spitting fuel into the engine, causing you to burn gas. I had this happen to a friend once, it was his injectors.
Hehehe. My car does that too. I asked the previous owner about it and he said to let it go because the car actually runs better if it burns gas. I believe him too because I noticed that my tach always drops to zero when it's not burning gas.
</TD></TR></TABLE>Hehehe. My car does that too. I asked the previous owner about it and he said to let it go because the car actually runs better if it burns gas. I believe him too because I noticed that my tach always drops to zero when it's not burning gas.
so i should replace the injector's ??
there's other thing there the hose is not connected..i'll take a picture of it.a.nd show you guys
bmw626
31
Jun 5, 2005 04:58 AM
